Volvo Truck ABS Trouble Code Help
Discussion in 'Volvo Forum' started by gwinnetts, Dec 27, 2014.
  1. gwinnetts
    gwinnetts Bobtail Member
    5
    [h=2]Volvo Truck ABS Trouble Code Help[/h]
    I have a 2012 Volvo VNL780 with a TCS light that stays on all the time. Trouble codes (active) are MID 136 SID 78 FMI 2 and MID 136 SID 77 FMI 7. Can anyone shed any light on what I need to look for to correct these?
    VIN is 4V4NC9TJ7CN558798. Engine is ISX. Any help would be greatly appreciated.
  2. reefer101
    reefer101 Medium Load Member
    434
    233
    Oct 24, 2014
    sensors on wheels or abs computer under the cab which costs around $1.700
  3. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,590
    Oct 11, 2010
    Borispol, Ukraine
    This code is much cheaper, just pressure sensors wiring!
    gwinnetts Thanks this.
  4. gwinnetts
    5
    Thank you . I will check the sensor connections. Those are located in the airbags aren't they?
  5. Pablo-UA
    7,604
    1,590
    Oct 11, 2010
    Borispol, Ukraine
    Depending on ABS/EBS configuration
    If u have truck with "traditional" foot brake valve demand sensors are used, if full EBS - sensor is built in brake valve.
  6. Pablo-UA
    7,604
    1,590
    Oct 11, 2010
    Borispol, Ukraine
    really the problem is that to reset code u need Knorr-Bendix software, it is called A-Com.
  7. Eagle-Vinnytsya
    Eagle-Vinnytsya Bobtail Member
    MID 136 SID 78 FMI 2 is on my 2013 670 isx 525hp. TCS light is ON
  8. Robson
    Robson Bobtail Member
    May 31, 2017
    MID 136 SID 77 FMI 2 2009 Volvo D13
    Solved the problem Air Pressure Switch Sensor part # 20476992 located on fairwall next to cluch pedal cost $70 at dealer and took 5 min to replace, B4 I spent over $1000 to replace valvs,sensors, itp itd at mechanic shop .... no help at all
    HopeOverMope, Johny41 and Socal Xpress Thank this.
  9. Huksn
    Huksn Bobtail Member
    Hi I have fh 12 2006 modil code mid136 psid 64 fmi 13 plz help
  10. Turtle356
    Turtle356 Bobtail Member
    Can someone please tell me what MID136 sid89 FMI5 means please
  • Draft saved Draft deleted
