Volvo vnl 2020 d13
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Ik73, Oct 27, 2022.
  1. Ik73
    Ik73 Bobtail Member
    5
    7
    Oct 27, 2022
    Truck died on me on Friday night, due to low fuel pressure. There was a leak from under the filter housing, when I tried to prime system. Had to be towed to the dealer. After replacing the housing they found that the fuel pump had to be replaced as well. Picked up the truck today and the same problem happened. There is a leak from under the housing. Drove only 200 miles. It seems like the problem is somewhere else, any ideas ?
    The same codes as previously:
    16 dtc p008a00
    16 dtf p008700
  3. Siinman
    Siinman Road Train Member
    5,533
    14,238
    Mar 5, 2017
    Kansas City, MO.
    First I have seen on this one. Following as well. Did you see any cracks on the hoses or the housing? Any pictures you can share?
  4. Ik73
    Ik73 Bobtail Member
    5
    7
    Oct 27, 2022
    Being honest not - don’t have any pictures
    Today I got it fixed, but not positive for how long it would last.
    That’s dealers comment
    “Found fuel leaking from primer pump button. Removed screws and primer top. Found internal pump to be loose and not secured into place. Tabs on internal piece are bent outward. Installed new primer. Truck ready for service”
  5. Siinman
    5,533
    14,238
    Mar 5, 2017
    Kansas City, MO.
    That sounds like a good fix for what you have said. New parts can be messed up and most likely it was a refurb part since most are on back order.
    Ik73 and Another Canadian driver Thank this.
  6. Ik73
    Ik73 Bobtail Member
    5
    7
    Oct 27, 2022
    So you think there couldn’t be such condition, when the fuel pressure suddenly grows too high, so it could damage what I mentioned above?
    I really appreciate your help, drove around 200 miles so far. Will let you know if smth happens again.
  7. Siinman
    5,533
    14,238
    Mar 5, 2017
    Kansas City, MO.
    Sounds like it was fixed in my eyes. Does anything feel wrong when you drive? Fuel is not leaking anymore correct?
  8. Ik73
    Ik73 Bobtail Member
    5
    7
    Oct 27, 2022
    Nothing is wrong now, but it never been wrong before. Nothing was leaking until just suddenly truck just stops running. I’ll keep you updated
  9. Siinman
    5,533
    14,238
    Mar 5, 2017
    Kansas City, MO.
    Something gave and caused air in the fuel. That caused the fault codes so it makes sense on how it happened. Good luck on future with it. Should be good to go make some money.
  10. Ik73
    Ik73 Bobtail Member
    5
    7
    Oct 27, 2022
    Couple days and no problems since. Do you think I can blame mechanics at first place? Since they replaced the filter housing and missed the problem with the primer pump or I just not fully installed it into place.
  11. Siinman
    5,533
    14,238
    Mar 5, 2017
    Kansas City, MO.
    I would guess they did nothing wrong and it was just faulty part. It happens to the best of everyone. Now if you have a relationship with the company then I would maybe ask for a favor be repaid when needed. If it is a one off shop just move on and forget about it. They will not do anything to offset it.m
