Volvo vnl 670 2011, Fan short cycling when ac on
Discussion in 'Volvo Forum' started by RoadRanger^^, Jun 25, 2025.
  1. RoadRanger^^
    RoadRanger^^ Medium Load Member
    327
    129
    Apr 17, 2018
    Columbus, OH
    Back again fellas,
    I have issues with my ac not cooling off enough. Here is the story. When i turn on the ac compressor runs for 30 seconds then shuts off and fan runs for 3-4 seconds and repeats and I’m thinking fan running that short is not enough to cool of the compressor. My friends truck when the fan kicks on runs around 50-60 seconds. Yesterday one of the airline broke and the fan was constantly on and the AC was blowing ice cold so i know the truck is not low on freon there is no leak in the system. What could be the issue ? Possible faulty high pressure switch ? No codes so far on the dash
    thank you
  3. Big Road Skateboard
    7,899
    46,064
    May 2, 2021
    You need to put some gauges on it. Sounds like it could be overfull, but gauges will verify what pressures are doing.
    Sounds like high pressure is spiking causing fan to engage and kicking out the clutch
    RoadRanger^^ Thanks this.
  4. RoadRanger^^
    327
    129
    Apr 17, 2018
    Columbus, OH
    Do you know by any chance what should be the numbers ? Or it depends of the outside temperatures ?
  5. Big Road Skateboard
    7,899
    46,064
    May 2, 2021
    Yeah I do, but it won't do you any good. Just hook em up and let us know what thet do. Even better, uplosd a video
  6. RoadRanger^^
    327
    129
    Apr 17, 2018
    Columbus, OH
    How can i upload video ?
  7. Big Road Skateboard
    7,899
    46,064
    May 2, 2021
    Most put ir on YouTube then link it
  8. Big Road Skateboard
    7,899
    46,064
    May 2, 2021
    Looks overcharged. Have you worked on it? I'd be getting some freon out of the system and see how it reacts.
    With the fan on, high side should be 170-200ish
    Low side 30-45ish
    Those are rough #'s, several factors in play there
  9. RoadRanger^^
    327
    129
    Apr 17, 2018
    Columbus, OH
    Yes i worked on it maybe couple months and recharged it myself with cans.
  10. Big Road Skateboard
    7,899
    46,064
    May 2, 2021
    See my edited post above. I'm surprised you haven't burnt up the clutch already
