Volvo VNL 780 Engine Brake
Discussion in 'Volvo Forum' started by Dsparil, May 27, 2017.
  1. Dsparil
    Dsparil Light Load Member
    147
    45
    Feb 23, 2017
    Ok so I assume the engine brake is always on since there's no button for it. How exactly does this device work and how do I control the engine brake? I tried watching a few youtube videos but they keep going on about cruise control. Is there any way to work the brake without having to use cruise control?
    Thanks
  3. boneebone
    boneebone Road Train Member
    2,297
    2,372
    Mar 13, 2009
    There's always a On/Off Switch for your Engine Brake and a Two or Three Stage Switch.
    It's either on the Dashboard or it could be on a Stalk on the right side of your Steering Column.
    Did your truck come with a Owner's Manual, most of the information you are seeking about your truck, you can find in the Manual.
  4. Dsparil
    147
    45
    Feb 23, 2017
    There's controls on the steering column. But no on and off that I could see. Owner's manual didn't say much.
  5. boneebone
    2,297
    2,372
    Mar 13, 2009
    I have a older Volvo VNL that has the Engine Brake Switches on the Dash, but I know the newer Volvo's have it on a Stalk on the Steering Column.
    Try carefully moving the Stalk towards you like if you were using your high beams on car or truck, that may be the On/Off Switch.
  6. CoyoteExpress
    CoyoteExpress Medium Load Member
    367
    174
    Oct 29, 2014
    Carlingford NB Canada
    Newer ones right suie from the steeringwheel
    Lower stick is for wipers etc.
    The UPPER STICK is for the engine bracke
    Watch lower left corner of you driver info display
    Stick posi ..... display
    Top ..............(off)
    1. ........... ...(A) automatic
    2. ............. (1)
    3. ............ (2)
    4. ............ (3)
    5. ......... (B) only on i-shift
    The (B) is a tip position and fall back to (3) it will force the i-shift to shift down if possibke by rpm to get a higher brakepower.
    Dsparil and KB3MMX Thank this.
  7. Dsparil
    147
    45
    Feb 23, 2017
    Ah ok thanks. that's what I needed.
  8. CoyoteExpress
    367
    174
    Oct 29, 2014
    Downhill limiter....
    When you go Downhill
    cruze off
    Engine brake stick on (A)
    Tip the + - on the stick to adjust the speed
  9. KB3MMX
    KB3MMX Road Train Member
    3,076
    2,596
    Dec 29, 2014
    Orrstown, PA
    Volvo really needs a short video on basic operation including their intermittent wipers how to adjust speed.
    For those unfamiliar it can take a while to figure out.
    Dsparil and mp4694330 Thank this.
  10. Dsparil
    147
    45
    Feb 23, 2017
    awesome precisely what I needed. I hate cruise control.
