Volvo VNL accelerator pedal or sensor
Discussion in 'Volvo Forum' started by Stringb8n, Apr 15, 2023.
  1. Stringb8n
    Stringb8n Road Train Member
    1,705
    2,235
    Sep 27, 2015
    Can the sensor itself be replaced or does it have to be the whole assembly? My pedal isn't working for the kickdown to make it downshift on its own. In 12th gear slam pedal to floor and it just accelerates slowly.
    Truck is a 13 volvo with D13 and Ishift.
  3. Siinman
    Siinman Road Train Member
    5,532
    14,237
    Mar 5, 2017
    Kansas City, MO.
    I am not on this but I assume you have had the kick down mode installed before the issue stopped?
    KB3MMX Thanks this.
  4. Stringb8n
    1,705
    2,235
    Sep 27, 2015
    It hasn't worked since I bought the truck. It has the resistance point, where it I guess clicks down before going all the way to floor but doesn't downshift. To knowledge from seller, it did auto downshift before.
    Siinman Thanks this.
  5. Siinman
    5,532
    14,237
    Mar 5, 2017
    Kansas City, MO.
    You may want to get a readout of the settings first to verify it is in it. I would start at that point since I do not trust anyone on what they say when buying something.
    KB3MMX Thanks this.
  6. Stringb8n
    1,705
    2,235
    Sep 27, 2015
    Do trucks that don't have kick down have the click feeling on the pedal?
  7. Animosus
    Animosus Heavy Load Member
    733
    2,916
    Dec 7, 2015
    SE Wyoming
    Yes. It is a parameter that can be enabled or disabled for kickdown.
    KB3MMX, Oxbow and Siinman Thank this.
  8. Siinman
    5,532
    14,237
    Mar 5, 2017
    Kansas City, MO.
    My truck does not have a click and has kick down.
  9. Stringb8n
    1,705
    2,235
    Sep 27, 2015
    Well XE package with premium shifter. If that doesn't include kickdown then idk. No way to check to see if it's enabled through dash on the truck? Has to go to dealer for a read out?
  10. Siinman
    5,532
    14,237
    Mar 5, 2017
    Kansas City, MO.
    This guy is 100 percent correct and the reason I said you need a read out of the parameters to confirm it has it. Most likely the owner had no clue what a kick down was.
    KB3MMX Thanks this.
  11. Stringb8n
    1,705
    2,235
    Sep 27, 2015
    Has to go to dealer for this?
