Volvo vnl cruise control not working
Discussion in 'Volvo Forum' started by goranvolvo, Mar 7, 2013.
  1. goranvolvo
    goranvolvo Bobtail Member
    19
    5
    Mar 2, 2013
    speed sensor new, brake pedal switch working , brake air pressure sensor working one next to clutch pedal on the fire wall , clutch switch working , engine brake working ,speedometer working , cruise will work when the truck is parked,will not work when in motion
    Controls for the cruise, of, on, resume, + and – all working when parked
    don't know what else to check
  3. Driveone
    Driveone Light Load Member
    53
    10
    Oct 26, 2011
    South Carolina
    In my experience it the sensor on the end of the transmission sensor where the Yoke is where the driveline hooks up a round one sometime hard to pull out dont be surprised if you break a few some call it the speedometer sensor but don't know the official name for it but in my experience that's what it was hope it helps.
  4. goranvolvo
    19
    5
    Mar 2, 2013
    it is speed sensor and i did replace it already
  5. Driveone
    53
    10
    Oct 26, 2011
    South Carolina
    Then hold up the break pedal with your foot and try it cause volvo has those problems I put a small bungy cord to hold mine up...
    deandrea1077 Thanks this.
  6. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,643
    Oct 11, 2010
    Borispol, Ukraine
    check clutch pedal switch and brake pedal switch. If you see brake light is off when pedal releases it does not mean brake pedal switch is ok, becouse brake loght is controled by pressure switch
  7. Pablo-UA
    7,604
    1,643
    Oct 11, 2010
    Borispol, Ukraine
    OMG) exuse me for poor spelleng... it is March, the 8.... Female's day here and we are drunk) LOL
    Pmracing Thanks this.
  8. goranvolvo
    19
    5
    Mar 2, 2013
    read my original post again
    all testing is done on the sensors and switches
  9. Pablo-UA
    7,604
    1,643
    Oct 11, 2010
    Borispol, Ukraine
    any VECU fault codes?
  10. Pablo-UA
    7,604
    1,643
    Oct 11, 2010
    Borispol, Ukraine
    can you rise up idle RPM with C/C switch?
    flood Thanks this.
  11. flood
    flood Road Train Member
    4,170
    4,054
    Dec 25, 2010
    never had a code and the controls always work when parked BUT mine will do that from time to time....... what i do is when driving hit the brakes quick then lift the brake pedal then it starts working like it should for days/ weeks/ months.... it's done it 4 times in the last 2 years,
    remember that when the dealer is checking it they are doing it when it's parked, and all the controls work when parked, you need to find a dealer that will do a ride along and have their laptop plugged in when YOU are driving
    Jacoooooooo, ydavidenko and Benek Thank this.
