volvo vnl electrical mirror not working
Discussion in 'Trucks [ Eighteen Wheelers ]' started by FreezingHot32, Jul 24, 2021.
  1. FreezingHot32
    FreezingHot32 Light Load Member
    115
    55
    Feb 15, 2018
    Upstate SC
    both driver and passenger side electrical mirror not working I did recently just replace all batteries not sure if that could be a cause. All advice greatly appreciated.
  3. lilillill
    lilillill Sarcasm... it's not just for breakfast
    5,642
    13,472
    Nov 7, 2007
    Possum Booger, Alabama
    Do the buttons light up when you select the left or right?
    FreezingHot32 Thanks this.
  4. FreezingHot32
    115
    55
    Feb 15, 2018
    Upstate SC
    no they are not
  5. lilillill
    5,642
    13,472
    Nov 7, 2007
    Probably needs the switch then. Hit the button repeatedly and see if it will light.
    Mine is crapping out for the driver's side. I have to hit the button three or four times to get it to switch on.
    I don't even want to know what it costs. It's an encoder, not a real switch.
    86scotty and FreezingHot32 Thank this.
  6. FreezingHot32
    115
    55
    Feb 15, 2018
    Upstate SC
    well through messing around the other night with my light on butttons did come on but im still not getting any action from either mirror.
  7. lilillill
    5,642
    13,472
    Nov 7, 2007
    If they worked before you replaced the batteries, maybe the memory that retains the settings in the LCM got wiped because of a bad coin battery. I'm pretty sure they are controlled through the LCM.
    I don't know if you can see any of that or diagnose it through Premium Tech Tool, but I have a copy and will look later today when I stop.
  8. 86scotty
    86scotty Road Train Member
    4,708
    12,918
    Aug 27, 2017
    Appalachia
    I'm betting on bad switch. It's a Volvo after all. Bad switches are common......real common.
  9. flood
    flood Road Train Member
    4,168
    4,047
    Dec 25, 2010
    1st check the fuse...
    If it's good it's the switch..
  10. lilillill
    5,642
    13,472
    Nov 7, 2007
    And once again, whenever I just want to have a quick look at something on PTT, it needs an upgrade and won't run. PTT is an expensive pile of garbage created by basement-dwelling, schizophrenic cat hoarders.
    Looks like yet another call to Tech support to get this piece of crap to update.
