VOLVO VNL FRONT END SHAKING
Discussion in 'Volvo Forum' started by RoadRanger^^, Apr 11, 2021.
  1. RoadRanger^^
    RoadRanger^^ Medium Load Member
    316
    117
    Apr 17, 2018
    Columbus, OH
    Volvo vnl 670 front end shaking even tho i installed two brand new tires. Shaking is around 45mph and then it seems like stops and again around 58-60 shaking. I have autobalancers on both wheels, mechanic said king pins are tied. What could be maybe bad balancers, bad rim or drum ? what do you guys think ?
    thank you
  3. Atlaw4u
    Atlaw4u Heavy Load Member
    750
    1,131
    Jun 8, 2018
    Was it shaking before the recent tire install?
  4. RoadRanger^^
    316
    117
    Apr 17, 2018
    Columbus, OH
  5. RoadRanger^^
    316
    117
    Apr 17, 2018
    Columbus, OH
    and driver’s tire was worn on the outter edge
  6. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    Time for a FT. end ALT. before you get the new tires into wear patterns that will not go away till the tires are worn like the ones you just took off, a tow/in that is off, will do will you saw happen to your old tires, and shake till you drive faster till you get it past the shaking?
  7. DUNE-T
    DUNE-T Road Train Member
    7,044
    17,156
    May 10, 2015
    Detroit, MI
    Find a good MD Alignment place, they will tight your bearings with DR Preload and do a good alignment
    flood and RoadRanger^^ Thank this.
  8. Johny41
    Johny41 Road Train Member
    1,192
    1,020
    Feb 10, 2011
    Ontario, Canada
    What kind of axle Hendrickson Steerteek air ride or simple Meritor?
  9. RoadRanger^^
    316
    117
    Apr 17, 2018
    Columbus, OH
    what is the difference between these two ? Front axle is not air ride only leaf springs idk if i answered your question correctly
  10. RoadRanger^^
    316
    117
    Apr 17, 2018
    Columbus, OH
    the most shaking is coming around 45 and around 65 you can tell something is bouncing but with low frequency
  11. Johny41
    1,192
    1,020
    Feb 10, 2011
    Ontario, Canada
    I used to have air ride on last truck and lots more things that could go wrong , air springs, valves fittings leaking, height out of specs.
    I would check the hubs , spring bushings shackle pins and bushings even drive line out of balance, hanger bearing, transmission output shaft and u-joints play. If the truck was towed and driveshaft removed , check if was not re-installed out of phase.
