Volvo VNL Starting Issues
Discussion in 'Volvo Forum' started by Volvotruck2019, Aug 7, 2019.
  1. Volvotruck2019
    Volvotruck2019 Bobtail Member
    13
    Jul 10, 2019
    I have a volvo vnl d16. I replaced the starter but my truck wont crank. I did a bypass and it starts but it wont shut off. Can anyone help me?
  3. boneebone
    boneebone Road Train Member
    2,297
    2,372
    Mar 13, 2009
    Did you use the ignition switch with the key when you started it or did you bypassed the ignition and went straight to the starter?
  4. Volvotruck2019
    13
    Jul 10, 2019
    I bypassed the ignition and went straight to the starter. The truck starts and runs fine but it does not want to shut off, I have to disconnect the batteries and alternator.
  5. boneebone
    2,297
    2,372
    Mar 13, 2009
    Are you trying to turn off the truck using the ignition switch?
  6. Amram
    Amram Medium Load Member
    448
    235
    Feb 4, 2017
    Are there relays under the dash console that control sending the signal to the starter?
  7. benrab
    benrab Medium Load Member
    326
    238
    Apr 5, 2015
    Quebec ,Canada
    Is The starter replacement have a relay with the both coil ends isolate ? What by pass you did ? Is your truck is manual transmission or Volvo I Shift ?
  8. Amram
    448
    235
    Feb 4, 2017
    Im a little teapot
    Reason for edit: Stupid samsuck crapaxy
  9. HopeOverMope
    HopeOverMope Road Train Member
    1,801
    3,211
    Feb 25, 2016
    I-20 LOUISIANA
    Possibilities, ignition relay, ignition switch, ignition fuses.
    Do your gauges sweep and work when you key on? If so your fuses are probably good. But you may have more than one ignition fuse. I’d replace all for good measure. Next i would check at the ignition relay. Unplug the relay. Test for power going into the plug while someone turns the key. If your getting power to the relay, id change the relay. Halfway in this starter video (around the 4min mark) I talk about changing the relay on a gen1 vnl. Mine was on the outside firewall, drivers side.
  10. 86scotty
    86scotty Road Train Member
    4,741
    13,012
    Aug 27, 2017
    Appalachia
    What does that have to do with anything?
    AModelCat Thanks this.
  11. Amram
    448
    235
    Feb 4, 2017
    My phone screwed up. I posted it under my thread but it went here.
