Volvo Vnm
Discussion in 'Volvo Forum' started by fspring, Mar 6, 2025.
  1. fspring
    fspring Bobtail Member
    we bought a 2012 VNM a couple of years ago. we just use it as a yard truck here at the farm. how do i switch which tank it draws fuel from? i dont see anything in the manual and dont see anything in the cab that indicates it. the passenger side tank its drawing from is getting low, but the fuel gauge says the driver side tank is still full. truck came with both tanks full and we still have not added any fuel. TIA
  3. Sons Hero
    Sons Hero Road Train Member
    3,032
    31,092
    Jan 8, 2021
    Indiana
    Peterbilt we have has a ball valve on the bottom of each tank, might be something like that. Or, the crossover line may be plugged, if you haven’t added fuel in several years, that’s what I would check first. Take the cap off driver side tank and make sure it IS full, could have a bad gauge or sending unit
  4. sirjeff
    sirjeff Medium Load Member
    Try cracking the cap on the tank that draws low and see if it equalizes the fuel level between the two. As far as I know, this truck should draw from both tanks equally
    I suspect one of your breather tubes are clogged
    86scotty Thanks this.
  5. nasriza
    nasriza Road Train Member
    2,407
    2,077
    Feb 1, 2013
    Chicago, IL
    the vent is plugged on driver side tank. volvo draws fuel from both tanks and returns to both tanks, you will find splitter valve behind trans mounted on crossmember there will be a valve for supply splitter to both tanks and return splitter.
