Volvo's turbo compounding D13 engine
Discussion in 'Volvo Forum' started by LastBradTrucking, Oct 20, 2016.
  1. LastBradTrucking
    LastBradTrucking Bobtail Member
    32
    6
    Oct 20, 2016
    50+ more horsepower and 6.5 % more fuel efficiency seems like quite an upgrade for the new upcoming Volvo's, how many of you think you will trade up for the new engine? Do you think it could break 9mpg? Also how much more do you think the newly outfitted Volvo will cost?
  3. me myself and I
    me myself and I Heavy Load Member
    736
    312
    Oct 5, 2009
    vernon hills,Il
    Two turbos. Yeah that's a great idea. All mechanics are starting to look for a new boats
  4. ryanbob1
    ryanbob1 Light Load Member
    121
    35
    Sep 9, 2016
    The old D12Ds 2003 2004 era had the turbo compound when they were u/s we used to put custom plate over the hole with an oil line and put a normal turbo on
  5. nasriza
    nasriza Road Train Member
    2,407
    2,077
    Feb 1, 2013
    Chicago, IL
    its not two turbos they are going to the same set up as cascadia has with dd15 has with the turbo compounding which has proved to be pretty efficient. they are also going to a common rail system like all the other engines in the market pretty much. what scares me is that they are cutting a lot of weight from their engine and this is going to be the interesting part they are making a lighter block also hollow camshaft again same as the dd15 but i guess time will tell. They are trying to compete with dd15 for fuel and reliability. it's better to wait a couple of years before they work out all the bugs before jumping into a new one that would at least be my opinion. the first year or two it's always a lot of problems for new designs.
  6. KB3MMX
    KB3MMX Road Train Member
    3,076
    2,596
    Dec 29, 2014
    Orrstown, PA
    Thanks for clarifying that
  7. 4x4_Welder
    4x4_Welder Medium Load Member
    300
    213
    Sep 16, 2014
    Eastern Orygun
    That's some high compression for a big engine. The turbo compounding sounds interesting, using spent gas to turn the crank a bit more. I thought someone did that back in the mid 90s, though-
  8. ryanbob1
    121
    35
    Sep 9, 2016
    yeah Volvo did the old D12D's 500hp 2002-2006 they are normally 460hp turbo compounded to 500
  9. Cowpie1
    Cowpie1 Road Train Member
    5,569
    4,652
    Nov 25, 2008
    Kellogg, IA
    Except that the DD15 now only uses one turbo, and a non-VG variety at that. They have gone back to a single asymmetric, waste gated turbo.
    From a purest standpoint, reliability should improve for Volvo over using VG design. It might be worth the move. But then, if folks would use turbo blankets on their VG turbos, they would save a lot of actuators on them. A blanket over the exhaust side of the turbo would increase flow thru there by not letting temps drop in the housing (creating a slight bottle neck thereby causing increased EGT's at the manifold), and would keep heat away from the actuator and intake side. I can place my hand right on the turbo blanket on a hot engine that has just done a grade under a load and not risk burning my hand. I have grown fond of turbo blankets since I started using them earlier this century. And no, I have not had to replace one turbo using a blanket.
  10. therebel
    therebel Bobtail Member
    6
    Jul 1, 2017
    Turbo compounding is not two turbochargers. It's a two-stage exhaust-side turbine system. The exhaust gases flow out of the exhaust manifold through the turbo outlet, spinning the turbine and increasing turbine speed, increasing the rotational speed of the turbocharger's inlet and compresses air into the engine; FOLLOWED BY the exhaust gases escaping the outlet into another turbine that is geared directly to the crankshaft, increasing power to the engine, which inherently reduces fuel usage and increases power because the engine is working less for the output and is being aided by a "power booster".
    Clear enough?
