Vovlo codes and truck issues
Discussion in 'Volvo Forum' started by ThreeM, Jul 10, 2017.
  1. ThreeM
    ThreeM Light Load Member
    56
    Mar 30, 2014
    Problem with my 1998 Volvo VNL, Cummins M11:
    Just after fueling the other day truck started vibrating while at low speed and accelerating.
    After gaining some speed the vibration stops.
    Couple of hour later the yellow warning light comes up with only 3 codes:
    MID 128
    PID 84
    FMI 10.
    Pulled over, started the truck again, clear the codes, no warning this time but the computer is now showing wrong fuel usage (it's showing 5.9mpg on average while I usually get 7).
    It is only the computer that is showing it wrong, the actual fuel usage is still the same so I wonder if something might be wrong with the computer itself?
    P.S. Truck is still vibrating at idle and low speeds.
    Any ideas where should I start?
  3. kemosabi49
    11,007
    48,076
    Jan 13, 2013
    SW Arkansas
    Bad fuel? Have you put any fuel in since then?
    CoyoteExpress Thanks this.
  4. ThreeM
    56
    Mar 30, 2014
    I was wondering the same. Only got another 80 gal after that ( from a different place for sure) but I don;t see a difference so far.
  5. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    Have you changed your fuel filters yet you may need to buy some extra filters an keep them in tool box till bad fuel runs thru?
  6. CoyoteExpress
    CoyoteExpress Medium Load Member
    367
    174
    Oct 29, 2014
    Carlingford NB Canada
    HOw high is the fuel in the glassfilter???
  7. shogun
    shogun Road Train Member
    6,075
    72,164
    Jan 23, 2009
    Doing a regen
    Google shows that code to be an erratic rode speed fault which may be an issue with the speed sensor on the tail of the transmission. The vibration at idle is a little trickier, can be several things, but a fuel filter issue usually rears its head under a load, just like an injector miss. You could use a temp gun and shoot the exhaust ports to make sure all the injectors are firing, the cold one is going to be missing, or run an injector cut out test with a laptop.
