W900 CB install ideas?
Discussion in 'CB Radio Forum' started by roundhouse, Nov 19, 2019.
  1. roundhouse
    roundhouse Road Train Member
    3,170
    7,209
    Jul 11, 2018
    Anyone have a way to install a CB in a late model W900-L without drilling holes ?
    The factory cubby above the windshield won’t fit any thing larger than cobra 29
    so either I got to figure out a way to get my superstar mounted without drilling any holes or find a very powerful cobra 29
    anybody made a bracket that mounts to existing bolts ?
    I like the above windshield location
    Leaves the dash clean , but I will consider whatever ideas y’all have used
    thanks
  3. Nothereoften
    Nothereoften Light Load Member
    261
    265
    Oct 6, 2018
    I use to have a tweaked and tuned galaxy 959. Fits the same space
  4. wolverine11
    wolverine11 Road Train Member
    1,629
    1,234
    Apr 1, 2015
    How much power does your superstar put out? If you dont want a " high powered" 29 ( will not sound good anyways if its ben modded) there are several radios being made ( Galaxy,Stryker, Mirage) that are 50 watt radio's that are same size as 29 and will fit in cb tray. I drive a T680 and have same dilema, would love to use Galaxy 99v2 but for now just use 29 or 980.
  5. roundhouse
    3,170
    7,209
    Jul 11, 2018
    As long as it fits in the cubby
    I have no idea how much power the superstar puts out
    But it will reach and receive about twice the distance of my peaked and tuned 29
  6. mickeyrat
    mickeyrat Road Train Member
    7,859
    7,542
    Nov 24, 2011
    on my 30 min break
    can that plastic surround be removed and reinstalled when needed?
    the tray and strap is what is needed. that surround is more cosmetic.
    an alternative is to see if you can buy the tray and mod as needed......
    I think the overall space is enough, just not with that surround.
  7. roundhouse
    3,170
    7,209
    Jul 11, 2018
    Someone suggested a Ranger RCI 39 vhp
    Good range and fits in the cubby slot
    anyone have any experience with that radio ?
  8. Timin770
    Timin770 Road Train Member
    1,657
    1,758
    May 27, 2011
    Canton, GA
    Anytone AT6666!!
  9. craig_sez
    craig_sez Road Train Member
    5,570
    2,714
    Sep 5, 2013
    novascotia,Canada
    The at 6666 is nice and same as stryker 447hpc2 but w/o side band..
    Just not a fan of the cooling design..It needs to have air flow to cool if your gonna be ling winded @ higher power levels..
    Are there any hd mount points in the above cabinet that you can use that already have bolts to use? Can always use factory radio bracket with a cpl holes drilled..
  10. roundhouse
    3,170
    7,209
    Jul 11, 2018
    Can’t drill any holes
    It’s an assigned truck no one else drives it but owner is meticulous about the condition
  11. craig_sez
    5,570
    2,714
    Sep 5, 2013
    novascotia,Canada
    No not drill hole in the trk in the radio bracket itself,then use exsisting bolt holes to mount if any..
    Im like you i dont believe in drilling hole in a trk..
    Didnt like my 955 in the cubby hole of my 19 cascadia..Almost bought the older cascadia dash mount bracket then someone here mentioned dbl sided sticky tape...I wasnt to keen on it till i gave it a try....
    On the previous version i used the upper cabinet vent holes for a bracket i made..Then i drilled the bracket to attach my radio bracket to and ran my coax/pwr/gnd to radio....Gotta be creative sir..
