W900 ecu problems
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Bmoore98, Apr 23, 2026 at 10:19 PM.
  1. Bmoore98
    Bmoore98 Bobtail Member
    Yesterday
    Hey guys. My old man drives a 1998 w900. N14 cummins with an 18speed behind it. We took the truck in after the transmission grenaded. Since then the speedometer hasn't worked. So we replaced the sensor. Still nothing, gentleman at the shop said to try another ecu. So we plugged that ecu in. Mind you, it's not throwing a single code. But the speedometer still isn't working, the fan won't shut off, and the cruise control won't work either. It still idles up when you turn it on, but when driving it won't hold a speed. Anyone had similar issues?
  3. MRMTRANS
    MRMTRANS Medium Load Member
    411
    441
    Apr 28, 2015
    Is the sensor positioned close enough? I'd check current in the sensor wires too. These are simple and can do yourself. Otherwise, I'd think you could hook a laptop with diagnostic software and start troubleshooting from there.
  4. Star Rider
    Star Rider Road Train Member
    1,801
    19,052
    Sep 23, 2019
    Pull the sensor out and stick your finger in the hole and see if you feel the teeth on the tone ring, they might have not swapped it from the old trans.
    Oldman83 and 062 Thank this.
  5. Big Road Skateboard
    7,209
    40,987
    May 2, 2021
    I don't think the yoke would ever tighten if it wasn't in there? The bearings never would anyway.
    But yeah, I'd look for a loose yoke. If that ring isn't tight, or worse, missing, it'll never work.
    Also make sure the wiring to the VSS didn't get between the bell housing and flywheel housing.
    Star Rider Thanks this.
