W900 LED headlights
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Cornhauler, Jan 3, 2022.
  1. Cornhauler
    Cornhauler Bobtail Member
    I have an 07 KW W900 that I attempted to put in dot led headlights. The low beams had a resistor diode. When I hook either low beam up they work but as soon as connect high everything goes out. It seems to mess up something because when I put the originals back in nothing works right, like right now I only have low beams. Could the control module be bad? Everything will work then nothing then... where could I start? Thanks
  3. FLHT
    FLHT Road Train Member
    1,437
    2,576
    Aug 2, 2014
    Ground the Green wires.
