W900 low pressure buzzer
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Moephilly1, Sep 30, 2018.
  1. Moephilly1
    Moephilly1 Light Load Member
    111
    35
    Oct 6, 2016
    Good evening truckers I recently bought a 207 W900 and I believe it has some electro issues. First thing is the driver electric door lock looks like it’s jammed. I press the unlock and lock button and it makes a buzzing noise and isn’t moving.
    Second my low pressure alarm isn’t working.
    Also when I open the doors the interior lights isn’t turning on I tried setting the dome light switch in the middle so it would turn the lights on when I open the truck but didn’t help.
    Also When I open ignition, no welcome sound or whatever it’s called buzzes. Thank you
  3. boneebone
    boneebone Road Train Member
    2,297
    2,372
    Mar 13, 2009
    The door lock actuator (motor) to be replaced.
    The buzzer for low air pressure and start up not working, it could be a instrument panel cluster problem. The buzzer could be bad on the circuit board and may need to be replaced.
    The interior courtesy light problem could be a bad door switch not giving a signal to the light to turn on.
    Moephilly1 Thanks this.
  4. Ridgeline
    22,720
    123,295
    Did you buy the truck blind?
    You should have seen a couple of these problems before hand and subtracted the repairs off the price.
  5. Cam Roberts
    Cam Roberts Road Train Member
    1,621
    1,938
    May 13, 2018
    Door lights and welcome sounds?
    I think that stuff broke on my 379 before it was delivered to the dealer from manufacture. You young guys need to toughen up as truckers lol
    Just bustin balls
  6. snowwy
    snowwy Road Train Member
    20,612
    13,333
    Jul 6, 2009
    my 07 w900 doesn't make welcome sounds.
    My door lock acts up once in a blue moon also. It be wise to disconnect the thing before you lock yourself out. Use the key to lock/unlock the doors
    Do you have an alarm with door open and yellow brake released? Mine does. I don't know if all that is tied in to one switch. But one switch is all I have in the door.
    The buzzers and red lights on the gauges should work below 60 psi.
    Don't know about the dome lights. 1 was there. Now both are missing. Neither worked. I have a new dome light setup now. It's wired to the switch. But doesn't work in the middle position so door open is no good.
  7. Moephilly1
    111
    35
    Oct 6, 2016
    Where can I find the circuit board and Change it ?
  8. Moephilly1
    111
    35
    Oct 6, 2016
    No I didn’t but I bought it for a good price
