W900 n14 celect
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Jdw900, Apr 24, 2021.
  1. Jdw900
    Jdw900 Bobtail Member
    16
    4
    Jan 19, 2021
    I need help with my n14 problem is that once truck reaches 180 degrees truck will derate will not go above 1500 rpms if you stop and let the truck cool down then it will run fine again and as soon as it gets to 180 degrees will loose power again I already change the intake temp sensor the water temp sensor, throttle position sensor, bypass the heat exchanger, bigger fuel filter and shutoff solenoid and still does the same thing. Also mechanic wasn’t able to find the diagnostic plug on the truck does any one know the location of it. Thank for the help
  3. 062
    062 Road Train Member
    6,329
    33,969
    Oct 20, 2013
    Plug should be left of the steering wheel above the fuse box. There’s another close to the ecm, but I don’t remember exactly where.
    Have you checked the voltage going to the water temp sensor?
  4. Jdw900
    16
    4
    Jan 19, 2021
    I have not check the voltage going to water temp sensor do you know how much should it be getting ?
  5. 062
    6,329
    33,969
    Oct 20, 2013
    I think it should be 5 volts.
    @BoxCarKidd @spsauerland may know for sure.
  6. Jdw900
    16
    4
    Jan 19, 2021
    I will check voltage tomorrow to see if I am getting 5v thank you
  7. Final Drive
    Final Drive Road Train Member
    1,573
    2,505
    Jan 21, 2015
    While you're at it..
  8. Jdw900
    16
    4
    Jan 19, 2021
    I already check that filter and is clean
  9. BoxCarKidd
    BoxCarKidd Road Train Member
    4,548
    6,641
    Aug 26, 2014
    I do not know your truck exactly but many have duel sending units. One for the gauge and one for the ECM. I would look for another one. The smaller L10 and M11's even had some on the right side of the block.
    Scanning for faults will be good if you get that connector located.
    spsauerland and 062 Thank this.
  10. Final Drive
    1,573
    2,505
    Jan 21, 2015
    Op
    Keep us updated on the progress..
  11. Jdw900
    16
    4
    Jan 19, 2021
    I am waiting to pick up my truck from mechanic so I can check voltage on temp sensor as soon as I know something knew I will keep you guys in the loop thanks
    Final Drive Thanks this.
