W900
Discussion in 'Ask An Owner Operator' started by Mr Bud, Nov 6, 2017.
  1. Roberts450
    Roberts450 Road Train Member
    2,237
    3,638
    Feb 6, 2016
    What tire size?
  3. Sportster2000
    Sportster2000 Road Train Member
    1,480
    886
    Jan 5, 2008
    Indiana
    That Cummins rep doesn't know what he is talking about. Peak torque comes in just below 1,200 rpm. You can take it to that rpm and it will be just fine. I've even run the Efficiency series down to 1,000 rpm cruising. They will survive just fine.
    Tb0n3 and MM71 Thank this.
  4. bobbyhill
    bobbyhill Light Load Member
    168
    151
    Aug 13, 2007
    Left Lane
    You say the Cummins rep doesn’t know what he’s talking about, well I’m here to tell you it will not pull a greasy string out below 1400
  5. Tb0n3
    Tb0n3 Road Train Member
    4,744
    9,663
    Oct 5, 2012
    Earth
    MM71 Thanks this.
  6. Mr Bud
    Mr Bud Bobtail Member
    31
    7
    Jun 23, 2016
    Yes ive already see n that but thanks
  7. Sportster2000
    1,480
    886
    Jan 5, 2008
    Indiana
    I've run up Eisenhower so many times running 1300 rpm in one and it does just fine.
  8. savage02
    savage02 Light Load Member
    163
    50
    Dec 21, 2007
    Upstate, NY
    I'm not talking about running it down to 1200rpm on a pull, I'm talking about running it under 1400rpm at cruising speed for long periods. I'm sure the Cummins rep doesn't know what he's talking about.
  9. savage02
    163
    50
    Dec 21, 2007
    Upstate, NY
  10. savage02
    163
    50
    Dec 21, 2007
    Upstate, NY
    Congrats on your new ride! You wont be disappointed with the engine.
  11. Sportster2000
    1,480
    886
    Jan 5, 2008
    Indiana
    I understand that, and like I said earlier it will still do the job just fine. There is no issue with running it at that rpm while cruising on the highway. The engine will still make enough heat for the aftertreatment at that rpm so you are good there and the engine life will not be affected by running it at that rpm either. That Cummins rep is just misinformed. It isn't like I've spent the last four years of my life working on and driving trucks with that engine in them.
