W900B 1lw 3406E help
Discussion in 'Trucks [ Eighteen Wheelers ]' started by jholveck, Jun 29, 2011.
  1. jholveck
    jholveck Bobtail Member
    6
    Grandview, Tx.
    I have a 99 W900B with a 3406E that has no power. I have checked the CAC and found leaks. I replaced it and seems better but still no guts. What can I do?
  3. logtrucker25
    logtrucker25 Light Load Member
    70
    9
    Jul 27, 2009
    northern CA
    check the fuel pressure at the secondary filter should be between 75-90 lbs depending on rpm. Also try pinching the wastegate line on the turbo an see if it improves the power. And take the intake off the turbo an see if the turbine can be wiggled. up and down is ok in and out means its worn out
  4. jholveck
    6
    Grandview, Tx.
    I did check the turbo when I had the CAC off.. it good. have not checked fuel psi yet. will check that. thanks
  5. jholveck
    6
    Grandview, Tx.
    fuel psi is good 80 psi at 900 rpm
  6. G/MAN
    G/MAN Road Train Member
    7,031
    8,625
    Sep 3, 2010
    Have you checked your air filter lately?
  7. jholveck
    6
    Grandview, Tx.
    yes did all the filters, clearances on turbo, lines, cooler,
  8. logtrucker25
    70
    9
    Jul 27, 2009
    northern CA
    How much boost are you getting? Has it thrown any codes? Also check around the exhaust manifold real close for cracks or leaks. Let us know if u figure out anything I'm chasing the same kind of problem on my E
