W900L ghost howl
Discussion in 'Ask An Owner Operator' started by jstran69, Nov 4, 2016.
  1. jstran69
    jstran69 Bobtail Member
    9
    I have a 99' W900L 72" aerocab studio, 550 Cat, 18spd that I've owned for about 10 years. Every year around this time it develops a howl that seems to come from the drivers side under the dash or firewall area. It comes and goes daily but I cannot duplicate it at will, seems to be only when it's cold outside. Just something that has always eluded me.
  3. sdaniel
    sdaniel Road Train Member
    5,511
    4,420
    Sep 7, 2011
    Pelham N.C.
    Air rushing in gets just the correct density when it gets cold enough ?
  4. 062
    062 Road Train Member
    6,328
    33,969
    Oct 20, 2013
    Pilot bearing,worn input shaft? Have you measured the ride height when it howls?
  5. 77fib77
    77fib77 Road Train Member
    11,653
    76,841
    Jul 7, 2010
    St Louis
    Exhaust leak? Build boost up and it sings?
  6. jstran69
    9
    No, thanks for the help though. It's done this as long as I've owned the truck. Definitely not exhaust leak or any of the other comments I received. I just assumed it must be a KW thing, it doesn't speed up or down, get louder, faster or anything. I used to think it was the heater years ago because it only seems to start as it gets colder outside but it does it with it off also. I have completely rebuilt this truck front to rear from engine, 7" complete exhaust system, air to air cooler, radiator, a/c system, transmission, clutch, flywheel, entire driveline including both rear ends, wheel bearings, etc and everything in between. Didn't know if anyone else had this ghost sound???
  7. kw550cat
    kw550cat Medium Load Member
    663
    596
    May 22, 2012
    brooklyn, new york
  8. 77fib77
    11,653
    76,841
    Jul 7, 2010
    St Louis
    Maybe it's space ghost
    jstran69 Thanks this.
  9. Yves kanevil
    Yves kanevil Medium Load Member
    522
    465
    Jan 10, 2016
    Nighthawk
    I have heard of haunted macks were the bulldog pisses on your leg while you drive but first time I hear of s haunted w9
    j_martell and jstran69 Thank this.
  10. ramblingman
    ramblingman Road Train Member
    1,152
    1,115
    Jan 12, 2014
    My 95 W9L is dang near silent inside.
  11. Dryver
    Dryver Road Train Member
    2,818
    2,576
    Nov 30, 2008
    Sioux Falls, SD
    When temps get cold rubber shrinks, so door seals don't seal as well. In summer rubber is more flexible and seals better.
