W900l no turn signal
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by biglion, Apr 9, 2020.
  1. biglion
    biglion Bobtail Member
    29
    37
    Mar 8, 2015
    With the help of this forum I brought my 1994 Kenworth W900l back to life. Now an endless list of detail work has to be done.
    One problem is, that the truck has no turn lights or hazard. The switch does not show a result. No flash, nothing.
    Where can I start and has a member here a wiring diagram for the turn lights?
    Thanks
  3. spsauerland
    spsauerland Road Train Member
    4,296
    10,892
    May 31, 2010
    West Harrison, In
    Probably the flasher relay. Repost last six of VIN and will get diagram in morning.
    SAR, biglion and pushbroom Thank this.
  4. biglion
    29
    37
    Mar 8, 2015
    Kenworth W900l, 1994, 614342
    Thanks
  5. bigguns
    bigguns Road Train Member
    2,846
    6,855
    Jun 13, 2013
    Omega,GA
    There is a very good chance it is above the panel with the diagnostic port.
    biglion and spsauerland Thank this.
  6. spsauerland
    4,296
    10,892
    May 31, 2010
    West Harrison, In
    Uploaded the turn/stop lamp diagram. The flasher is just your standard HD 12V negative ground flasher. Paccar P/N would be a CB12050. Its located behind the instrument panel, two wires, red 2ST and Yel/grn L70TN. Good luck and let us know!
    SAR, bigguns, pushbroom and 1 other person Thank this.
  7. biglion
    29
    37
    Mar 8, 2015
    Thanks. Will check out and inform you.
    spsauerland Thanks this.
  8. biglion
    29
    37
    Mar 8, 2015
    Problem(s) solved. It was a ground problem plus the flasher.
  9. Caterpillar Cowboy
    Caterpillar Cowboy Heavy Load Member
    837
    608
    Nov 11, 2010
    Wyoming
    Most of my electrical problems are found right on the clamps that keep the wires / loom up and out of the way.
    Always find it ironic how the things they add to keep us from having problems are where the problems happen!
    biglion Thanks this.
  10. pjocasio65
    pjocasio65 Bobtail Member
    Help, 2018 kenworth w900 no signal light in the front, rears are working, can't find the problem
  11. pjocasio65
