Wabco 4s/4m ABS problem.
Discussion in 'Freightliner Forum' started by Nealk2, Jul 8, 2024.
  1. Nealk2
    Nealk2 Bobtail Member
    Aug 27, 2022
    Kiaora.
    I have an issue with a wabco ABS self test.
    On ign on the unit will not self test. No 3sec flash. It’s not the bulb.
    After checking it over I found there’s no power
    to the ECU test switch on the unit.
    Another head scratch. There is 12.5 Volts at the wheel spin signal pin. 18 pin plug. Pin 16.
    I can’t find any info on what pin should have what voltage.
    Any Wabco experts out there.
    Rideandrepair Thanks this.
  3. Rideandrepair
    17,561
    56,895
    Aug 8, 2015
    I had that problem, the power harness was the problem. Mine was about 10 ft long, plugged into another harness along the side rail that ran up to the pigtail. In other words work back with a test light from the ecu. You can repair a broken wire., but it’s a DOT violation. Wabco site has all the information you could possibly need.
  4. Rideandrepair
    17,561
    56,895
    Aug 8, 2015
    D8C290A0-1A37-41C1-9554-1D4FF59DB15E.png My link no longer exists. I found this, same website. Has all the info you need.
  5. Nealk2
    Aug 27, 2022
    Thanks. Yep. Not legal.
    There’s 12.5 volts on both pin inputs in ECU so I think it’s alive.
    I gotta figure out what powers the ECU test switch. The wires to that that are dead.
    Thanks for commenting
  6. RocketyMan
    RocketyMan Medium Load Member
    549
    337
    Jun 5, 2015
    You posted in the freightliner forum, but still have no idea what unit you are running.
    If you want some substantial help, post your last 6 of VIN so I can look up wiring applicable to your unit.
    QUALITYTRUCK Thanks this.
  7. Nealk2
    Aug 27, 2022
    Roger that. Will do. Soon
  8. Freddy2times
    Freddy2times Light Load Member
    64
    31
    Feb 12, 2019
    Scan it,
