Hi All,
I live in africa, sitting with a midlife crisis, and want to do something else, namely truckin.
What I have at the moment: potential contracts, and a dash of money.
There is a school where I can learn to ride etc, but the financials I am a bit concerned about, and maybe you can help on this.
The contract:
850 miles moving grain, roundtrip (50% full load, 50% empty load)
Roads will be tar, with minor gravel for loading.
min 25 loads per month as per sla
Looking at truck: International Eagle 9800I autoshift about 250k miles, 2008, with sleep cab, with interlink bins (34Ton). New tyres
I have the following questions:
What is the life span of steering, pulling and trailer tyres?
Would it be wise to move over to the wider michelin tyres available (The one tyre that replaces 2, with light weight rims)
I find a lot of people talk about 6mpg. Would I be able to get this kind of gas usage? The road is 50% hill country, 50% flat. Also, what is the difference in mpg with full/empty load
Your help appreciated.
Wannabe making cost calculations for o/o
Discussion in 'Ask An Owner Operator' started by potatoman, Jun 29, 2011.
Your questions are valid, but there are a number of variables. Tire life and mpg are as much related to the driver and how he handles the equipment than the equipment or terrain. If you check tire pressure regularly and keep air at the same point, it will prolong the life of your tires. Terrain is important, but not as much as the habits of the driver. You can blow a tire at any time. I would expect steer tires to have a life of 80,000-150,000 miles on average. You could get more miles from your steers with good maintenance such as having regular alignments. I would expect that driving on tar and gravel roads would reduce the life of tires somewhat over running on asphalt. In doing calculations, I would be confident of the range that I listed. If others are getting 6 mpg, then I would expect that you could do the same. When I do estimates I use 5 mpg. It is best to expect lower mpg than to over estimate your fuel economy. When it comes to calculating fuel consumption from loaded to empty, you could get 1+ mpg empty, depending on terrain and conditions. If you drive in an area that has a lot of wind or mountains, then your mph will likely be lower than if you drive mostly on flat roads.
bullhaulerswife and BigJohn54 Thank this. -
Thanx G/MAN,
do you know estimates on the drive/trailer tyres? -
I would expect to get about 150,000-250,000 on drives. Again, it will still depend on your air pressure being checked regularly. I have heard some say that they have gotten as many as 400,000 on their drives with Michelin. I doubt you would be able to get that many, especially with the type of road that you will be traveling. You should be able to get comparable miles as I noted on your trailer unless it is a spread axle. You may not get more than 80,000 on a spread axle tire. If you have a spread axle with a dump valve then you should be able to get more miles from your tires.
It will nearly always come back to the driver and how well you do your pre-trip and maintenance. You will blow tires from time to time and that will skew your average miles per tire. Keeping tire pressure up will minimize the possibility of a blowout.BigJohn54 Thanks this.
