Warning for those that run Rangers with an internal amp.
Discussion in 'CB Radio Forum' started by lilillill, Sep 18, 2017.
  1. lilillill
    lilillill Sarcasm... it's not just for breakfast
    5,642
    13,472
    Nov 7, 2007
    Possum Booger, Alabama
    I'm pretty sure I burned up the amp in my N4 by hooking up a battery charger to my truck while I was off. I didn't realize the amp section stays powered up anytime the radio is plugged into power.
    Anyhow, I got in my truck while the battery charger was hooked up and noticed that my inverter was beeping with an over voltage error and showed 17 volts on the display. The next thing I noticed was that the fan was running on the amp on my radio and the radio was off.
    I hooked up a watt meter to the radio just to have a look and now the dead key is a maximum of about 30 watts on AM, even with the power turned all the way up.
    I open it up, and it appears I killed three of the four transistors. The one good one heats up really fast to over 200 degrees as soon as you key the mic and the other three hover just above ambient temperature.
    So this brings me to my question… Can I just put a matched set of transistors in it and it will be good to go, or does something need to be adjusted after replacing the transistors?
    I don't see anything physically burned in the amp. All of the resistors and caps look ok.
  3. Ridgeline
    22,828
    125,848
    There is nothing to adjust if I remember.
    Just pop in a new set and check it.
    I would also relay the power to be off when you have the key off to prevent this from happening again.
    Who put on an 18 volt charger on the truck, you are not an 18 volt system.
    Blaskowitz and lilillill Thank this.
  4. lilillill
    5,642
    13,472
    Nov 7, 2007
    It's an automatic charger and apparently it pulses the voltage really high at first to blast any sulfate off the plates. It works, because after putting it on the charger, the starter spins over faster and my APU will cycle instead of running nearly constantly. The effect lasts for a couple of months.
    It seems to me the radio drew 35 amps at full tilt when it was new. The only relay I can think of right off the top of my head, with big enough lugs and rating, would be like a Ford starter relay. But I don't think those are meant for continuous hold-in. Got a relay in mind?
  5. Ridgeline
    22,828
    125,848
    Desulfating a battery is putting a voltage on the battery and injecting a signal into the voltage. If you are seeing this lasting a few months, I can't imagine what you are doing to the batteries, you have to be draining them to nothing to cause sufide buildups.
    Relay?
    Well get an A/C relay from an autoparts store for a truck, they are 40 amp. You won't have to worry about it burning the contacts, you are not switching 35 amps but maybe .5 amp.
  6. breadtrk
    breadtrk Heavy Load Member
    788
    823
    Oct 4, 2015
    I use a 100 amp Ford tractor relay on my N4. I know that's overkill but there is 43 amps flowing through those contacts at full song on mine measured with a fluke dvma.
    A fancy battery charger fried my ffb4 same way as yours. Expensive lesson.
    rabbiporkchop and lilillill Thank this.
  7. lilillill
    5,642
    13,472
    Nov 7, 2007
    IMG_1039.jpg Are you talking about one like this? Will the windings handle being powered up all the time?
  8. lilillill
    5,642
    13,472
    Nov 7, 2007
    4 gauge cable... not going to be using spade terminals on that.
  9. Ridgeline
    22,828
    125,848
    OK ...
    The 40 amp relay is continuous duty, the start relay is not.
    4 gauge for a 35 amp draw?
    rabbiporkchop Thanks this.
  10. lilillill
    5,642
    13,472
    Nov 7, 2007
    It is a very long run going back to the batteries. The cables coming out of the amp are 6 gauge. Any relay is going to have to have lug terminals. Or at the very least, screw terminals.
  11. Ridgeline
    22,828
    125,848
    You can get continues duty relays with posts on them, they are 100 and 150 amp relays, not costly, they are pancake types. I went though a number of those starter relays a while back with a power pak on my truck and went to a 300 amp continues duty relay and never replaced another.
