Washing an old tractor
Discussion in 'Ask An Owner Operator' started by Mcast3092, May 24, 2021.
  1. Mcast3092
    Mcast3092 Light Load Member
    137
    107
    Jul 31, 2018
    Hello everyone, I was looking for a little advice on how to wash an old tractor. I bought a ‘97 t600 off a farmer. The truck has minimal rust and seems to be in overall good shape but the chassis is incredibly dirty. It was on the fields ALOT so it has dust, rocks, and debris in every crevice. Truck is very dusty. Looking for some washing tips to get her as clean as possible. I’ve washed with degreaser, used zep truck and trailer wash, and am using a hot water pressure washer but the truck is still very dusty. Any tips would help!
  3. Dino soar
    Dino soar Road Train Member
    4,815
    27,071
    Dec 8, 2017
    My advice would be that you're not going to get all the dust looking things off of the outside of the frame rail. That part you have to sand and paint even if you just sand lightly.
    If you're cleaning the inner part of the frame where you have Grime and whatever around like say the hangers for the springs on the outside or the bolts and cross members on the inside, and that type of thing you have to get a putty knife and scrape everything off the best way that you can.
    It's a really dirty job but if you want it even cleaner you can take gasoline and a Parts brush and use that. That should get everything off.
    Rideandrepair and Mcast3092 Thank this.
  4. Dale thompson
    5,452
    47,193
    Nov 20, 2013
    commerce twp,mi
    How big of a pressure washer? Get a turbo tip and just keep going over it again and again it probably has oil leaks and farmers tend to just let the dust cake everything up. I recommend a power washer of at least 3500 psi and 1.5 gallons per minute for a job of this nature.
  5. Mcast3092
    137
    107
    Jul 31, 2018
    I’m going to be hitting what I can with a needle scaler, after that I’ll do some light sanding. What concerns me most is the under carriage. Every wire and air line is covered in dust. I appreciate your help
    Rideandrepair Thanks this.
  6. Dino soar
    4,815
    27,071
    Dec 8, 2017
    And you probably could used a Scraper on the airline's just be careful and then you probably could use lacquer thinner to wipe them down because that dries very quickly.
    I suppose you could do the same for the wires. Just be gentle that you don't pull on them but I'm sure you will be.
  7. Rideandrepair
    17,562
    56,901
    Aug 8, 2015
    You almost have to take a rag, soaked in anything petroleum based, and wipe it down. Gasoline is cheap, evaporates fast. Cleans the best.
    Mcast3092 Thanks this.
  8. Rideandrepair
    17,562
    56,901
    Aug 8, 2015
    I’d really appreciate it if you’d stop by and demonstrate the scraping part. I did some of my fuel tanks. Must have not done it right. Had grease everywhere, all over Me. I’d be willing to buy you a six pack, to finish the job. It’s a pretty good deal.
    Dino soar and LameMule Thank this.
  9. Don379
    Don379 Heavy Load Member
    714
    1,286
    Jan 7, 2021
    muriatic acid on cab and all parts
  10. Rideandrepair
    17,562
    56,901
    Aug 8, 2015
    My neighbor hired a portable wash Truck. Then Put on his Coveralls and didn’t the work himself. I could have done mine too. It’s a nasty job. Need paint right away, on any bare metal.
    Dino soar Thanks this.
  11. Rideandrepair
    17,562
    56,901
    Aug 8, 2015
    If using acid, has to be neutralized with baking soda. I did my last Trailer, didn’t neutralize it afterwards. The rust set in, and couldn’t be stopped. Acid works great on rust, but must be neutralized. That’s blue beacons trick, hit with acid, soak, neutralize and rinse.
    Dino soar and Don379 Thank this.
