Water in rear ends?
Discussion in 'Mack Forum' started by Vthayman, Feb 2, 2014.
  1. Vthayman
    Vthayman Bobtail Member
    Has any body ever gotten water in their Mack rear ends?
  3. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    Is the vent still on the axel? it can get top knocked off and fill up from run off from tank.
  4. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,734
    Apr 18, 2010
    Tennessee
    No but it will help eat your bearings up if you don't get it cleaned out.
  5. PackRatTDI
    PackRatTDI Licensed to Ill
    14,765
    22,569
    Jul 15, 2006
    El Chuco, Tejas
  6. GA_Rookie
    GA_Rookie Medium Load Member
    391
    307
    Dec 14, 2012
    Northwest, GA
    Sounds like a personal problem to me. You may want to see a doctor and get that checked out! I would HATE to have water in my rear end!
  7. Hardlyevr
    Hardlyevr Road Train Member
    3,270
    2,540
    Jul 30, 2009
    Mapleton Depot,PA
    The 2 most common causes are from either excessive condensation, which usually means you have vent problems, or from driving through deep water, and you definitely have vent or worse problems.
  8. Wooly Rhino
    Wooly Rhino Road Train Member
    3,367
    5,648
    Jul 6, 2008
    Liberty, Missouri
    I want to make a commit about condoms being used as water balloons but I am too polite.
  9. dude6710
    dude6710 Road Train Member
    2,162
    622
    Mar 26, 2010
    MN
    I had water get in mine from a vent leaking. Lets just say I had to buy a new 3rd member because it wasn't caught fast enough. $3800 mistake
    lets just say there was huge chunks of metal in the oil and they almost didn't accept my core.
  10. alaga
    alaga Light Load Member
    195
    62
    Jan 9, 2012
    Fayetteville, GA
    YES!!! Had the same wheel-end seal go out 4 times over a 3-week period, always had water in the fluid. Had the local Mack dealer doing the work, and they seemed confused since I denied driving thru deep water every 4 days. Replacing the vent didn't help. At least I only paid for the first repair.
    Finally someone in the shop decided the rears needed to be re-sealed since every time I worked on a rainy day the seal blew. Didn't know there was such a procedure; big labor charges, but very little parts since they used what appeared to be white silicone sealant along the horizontal surfaces of the rear halves. But at last the problem was solved! May be your problem as well...
  11. Natew_m88
    Natew_m88 Bobtail Member
    Muskego WI
