Water in Wilson 2000
Discussion in 'CB Radio Forum' started by Joetro, May 20, 2019.
  1. Joetro
    Joetro Road Train Member
    2,417
    2,411
    Aug 23, 2008
    Post Falls, ID
    I bought a Wilson 2000 off Craigslist that was in like new condition. The antenna works great, but, after running in weather, the housing has water in it. I'm assuming this probably isn't good for it. My thought is to drill a hole in the bottom and drain it, then blast some WD40 in there to displace any remaining moisture.
    Anybody have any thoughts on this? I'm sure the water can't be helping the SWR, not to mention the corrosion that will most likely take place.
  3. craig_sez
    craig_sez Road Train Member
    5,570
    2,714
    Sep 5, 2013
    novascotia,Canada
    Seems that might be an older one if i remember correctly...Just find ways to seal it up once you get it all dried out...Stuff called coax seal will work..
    Joetro Thanks this.
  4. rabbiporkchop
    9,678
    6,545
    Feb 9, 2012
    Wapwallopen, Pa
    The Chinese ones aren't as watertight as the older American ones. Drilling a hole in the bottom might be the only option.
    The water needs to be removed.
    Joetro Thanks this.
  5. Joetro
    2,417
    2,411
    Aug 23, 2008
    Post Falls, ID
    Thanks for the advice. I'll drill a hole, get the water out of it and reseal it. It sucks that quality isn't at the top of the list anymore.
  6. Slowmover1
    Slowmover1 Road Train Member
    1,491
    1,210
    Oct 25, 2015
    Fort Worth
    Drilled holes in my pair one week after buying in 2014. They’re fine now.
    Joetro Thanks this.
  7. BTShepp
    BTShepp Blue Demon
    373
    215
    Oct 31, 2015
    Chicago, IL
    On the bright side, it upgraded itself to a water-cooled antenna. ;)
    Joetro Thanks this.
  8. craig_sez
    5,570
    2,714
    Sep 5, 2013
    novascotia,Canada
    Bt.......What if it was salt water???? Maybe he was goin flat out on the fla coast enjoyin the warm air of the beaches with ocean spray soft bikini clad bodys and ......Oh shoot im wonderin off topic..lol
  9. jessejamesdallas
    1,416
    855
    Oct 3, 2008
    Republic of Texas
    It's only a mater of time before it's done...IT WILL SHORT-OUT!...just a mater-of-time now...The 5000 isn't any better by the way...Here's the insides of a Wilson 5000 that got water in it, and shorted out.
    sealing it up at this point may only aggravate a already bad situation, since sealing it up will trap the water that's inside from getting out...
  10. craig_sez
    5,570
    2,714
    Sep 5, 2013
    novascotia,Canada
    Jj.Op said he will dry then seal......Wonder what antenna is mounted on..
    jessejamesdallas Thanks this.
  11. jessejamesdallas
    1,416
    855
    Oct 3, 2008
    Republic of Texas
    still not going to be able to get completely dried out...unless he takes it apart...I had to use a dremel tool to open mine up.
