Water leaking into my cab, need help! Western Star 4900
Discussion in 'Trucks [ Eighteen Wheelers ]' started by DLament, Dec 31, 2024.
  1. DLament
    DLament Bobtail Member
    41
    25
    Mar 12, 2022
    The truck is an 07 western star 4900 daycab and the water pours in the cab every time it rains! At first I thought it was coming in at the hvac air inlet so I plugged that off but it's coming from somewhere above the hvac box on the passenger side and above the clutch pedal on the drivers side. It's a constant drip when it's raining hard! I had a beach towel on each side over the weekend and they were completely soaked after it rained! I have silicone everything on the firewall I could find as well as the roof, although I don't get any drips from the roof. I'm out of Ideas..
  3. ‘Olhand
    ‘Olhand R.I.P.
    6,750
    16,654
    Jan 18, 2011
    Ck around the clearance lites
    Or anything else mounted to roof
  4. DLament
    41
    25
    Mar 12, 2022
    It seems to leak in behind the dash somewhere because it runs down the firewall, I'm thinking it may be the seal around the windshield because I see some water along the bottom of the windshield, no runs or drips from up above
    TX2Day and tscottme Thank this.
  5. FLHT
    FLHT Road Train Member
    1,487
    2,750
    Aug 2, 2014
    When you find the leak... Flex Seal
  6. bad-luck
    bad-luck Road Train Member
    3,509
    6,503
    Nov 16, 2013
    Baltimore, Maryland
    Check the windshield
    Opus and DLament Thank this.
  7. rbrtwbstr
    rbrtwbstr Road Train Member
    3,420
    8,010
    Jul 11, 2012
    in the bush somewhere
    Windshield. Company i work for has a handful of Western Star's and I think they all had leaks at the windshield.
    DLament Thanks this.
  8. DLament
    41
    25
    Mar 12, 2022
    That's kind of what it seems like. What did they do to fix them?
  9. rbrtwbstr
    3,420
    8,010
    Jul 11, 2012
    Removed them and re glued them.
    Other thing to check is the lights on the roof. The roof cracks around the lights
