Water level
Discussion in 'Ask An Owner Operator' started by Adriantx, Sep 23, 2021.
  1. Adriantx
    Adriantx Light Load Member
    64
    17
    Dec 29, 2018
    Dose anyone know if water level should drop when turning on truck after its been off for 10hrs or more hrs?
    My trucks water level drops when turning on truck after a few minutes as it's getting warmer it levels out without me adding coolent is this normal I have a cummins isx15?
  3. Spyro2112
    Spyro2112 Medium Load Member
    624
    434
    Mar 17, 2018
  4. Spyro2112
    624
    434
    Mar 17, 2018
    Thermostat may b stuck open
  5. Adriantx
    64
    17
    Dec 29, 2018
    Just changed it?
  6. Rideandrepair
    17,574
    56,926
    Aug 8, 2015
    It’s probably normal. Thermostats are closed and coolant runs through the bypass back to waterpump. Once they open it drops, temporarily as it goes into radiator, then from heat expansion eventually comes back up. I can only guess. Not familiar with the newer engines, but I think they’re designed to run under higher pressure to keep temps down. Being a closed system under more pressure, would make sense. Same way with newer cars vs older ones. Hopefully someone with the exact set up will chime in.
  7. Ridgeline
    22,742
    123,685
    What do you mean drops?
    In the expansion tank?
    how much?
  8. Adriantx
    64
    17
    Dec 29, 2018
    In Reservoir, level gose from max full level to min level then after 10min it's back to max full level
  9. uncleal13
    uncleal13 Road Train Member
    3,797
    6,299
    Apr 9, 2009
    Humboldt, Sk
    Normal. Suction of water pump pulls it down. Heat expansion makes it come back up.
    lester Thanks this.
