Water pump or radiator question.
Discussion in 'Ask An Owner Operator' started by Keepforgettingmypassword, Feb 10, 2022.
  1. Keepforgettingmypassword
    Keepforgettingmypassword Heavy Load Member
    738
    938
    Jan 11, 2022
    I can post pictures if nessacary,
    On the hose connected from the water pump to the radiator. It's rubber off of the pump then metal then rubber again at the radiator.
    A couple weeks ago, I noticed what I thought to be a rust color leak where the radiator rubber hose meet the medal one. I couldn't con from this at that time do to another leak leaking down to it.
    Ive since keep it clean at that connection and tight. Before I make a big mess trying to figure out which component is it, is there any tips or tricks to isolating it, or can antifreeze take on a rust color and not affect the rest of it?
    To date the reservoir antifreeze thats visible is still normal color, thats why I ruled out the egr cooler as the mistry leak.
  3. Keepforgettingmypassword
    738
    938
    Jan 11, 2022
    P.s. my buddy thinks it might be the pipe
