Water temp guage not working
Discussion in 'Trucks [ Eighteen Wheelers ]' started by ready2truck, Jun 18, 2021.
  1. ready2truck
    ready2truck Medium Load Member
    301
    352
    Oct 27, 2020
    05 Freightliner water temperature not working. Shop said when they plugged in the ecm it showed water temp. When I ground the guage out the needle will max out. Could the guage still be bad? What should I test next?
  3. AModelCat
    164,923
    You ground the gauge it pegs out and with the wire off it goes back to zero?
    I'd suspect the sensor is toast. Most trucks of that era had a temperature sensor for the ECM and a seperate one for the gauge.
    ready2truck Thanks this.
  4. ready2truck
    301
    352
    Oct 27, 2020
    Yeah it maxes out then goes back to zero. Do you know the location of the sensors?
    It's a c15 acert
  5. Roberts450
    Roberts450 Road Train Member
    2,237
    3,638
    Feb 6, 2016
    Both should be in the thermostat housing which is top right/center of the engine just under the upper rad hose.
