Water temp help
Discussion in 'Ask An Owner Operator' started by Mohtrucker, Jan 13, 2021.
  1. 6wheeler
    6wheeler Road Train Member
    2,696
    4,774
    Aug 30, 2009
    No one on here will understand this but I have been doing this for 10 years with no problem.
    I experience the same issue and here is the fix.
    16x16 inch cardboard held on to the grill by a bungee cord. Take it off when the temperature get above 40
  3. snowwy
    snowwy Road Train Member
    20,618
    13,340
    Jul 6, 2009
    I understood that one just fine
    God prefers Diesels and 6wheeler Thank this.
  4. 6wheeler
    2,696
    4,774
    Aug 30, 2009
    There is a lot of folks that believe, that's not factory designed or just not right.
    And in the summer time it's good to remove the thermostat. You don't want 210+ degree temperature climbing a mountain in 90 degree temperatures. Crack a head, turbo, hose...
  5. Ridgeline
    22,778
    124,622
    I take this back, first change the water temp sensors then the thermostats.
  6. Oscar the KW
    Oscar the KW Going Tarpless
    12,247
    28,120
    May 19, 2011
    If he looses heat going down the road it’s a thermostat.
    flood and lester Thank this.
  7. Ridgeline
    22,778
    124,622
    Yeah but I thought about this this morning and think that changing out the temp senders should be done to ensure that the gauge and ECM see a correct temp.
    I had a car that the gauge was showing it always cold, taking the temp at the hose coming out the engine, the temp was cold but not cold like the gauge showed.
    so because he has the system drained to replace the thermostats, might as well replace the sending units.
  8. Johny41
    Johny41 Road Train Member
    1,192
    1,020
    Feb 10, 2011
    Ontario, Canada
  9. Mohtrucker
    Mohtrucker Light Load Member
    135
    188
    Oct 20, 2019
    Can I get back to my hometown with this issue or is it an immediate fix ?
  10. Ridgeline
    22,778
    124,622
    Fix it now, it causes problems with the oil and sludge, not to mention increasing wear in the cylinders.
  11. Oscar the KW
    12,247
    28,120
    May 19, 2011
    I probably would, I went from AZ to IA with a thermostat that was stuck open.
