Water temp troubles
Discussion in 'Peterbilt Forum' started by Mervin159, Oct 11, 2022.
  1. Mervin159
    Mervin159 Bobtail Member
    Oct 11, 2022
    04 379 with Cat C15. Water temp high warning comes on but gauge only gets up to 150. I do think it is actually hot so gauge has to be wrong, right? What is most likely the problem?
  3. bad-luck
    bad-luck Road Train Member
    3,449
    6,359
    Nov 16, 2013
    Baltimore, Maryland
    Get yourself a thermo heat gun. Check the tem that way. Sounds like your guage is not working.
  4. lester
    2,957
    8,087
    Jan 2, 2012
    NW, Iowa
    There's to sensors, one for gauge and one for ecm. I assume warning light comes on when ecm sees high temp. Gauge in peterbilt is pretty well known to be inaccurate. I run a scangauge so I see the temp ecm sees. Never had much luck with dash gauge working well.
    Is fan kicking on? Is radiator dirty?
    Fan kicks on for water temp at 217.
    MartinFromBC Thanks this.
  5. MartinFromBC
    2,769
    12,484
    Oct 19, 2018
    Hose collapsing internally, thermostat stuck, low on coolant, fan failing, rad plugged?
  6. Mervin159
    Oct 11, 2022
    Blew radiator out yesterday and running at normal temp now, which I figured was the issue. Should’ve phrased my question better. Was asking more about fixing the gauge than what was causing truck to get hot. Thanks for the replies
    baha and MartinFromBC Thank this.
