I have a 2006 volvo with Cummins isx. My 6 stage engine brake is weak. Wont holf me even on high while am empty. I thought a valve adjustment would fix the problem but it didn't. Did overhead adjustment yesterday. No change. It only has 2 jake brake selonoids which we didn't test. Any insight? Thanks
Weak Engine Brake on Cummins ISX
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by kabusheke2004, Nov 28, 2018.
its probably your solenoids, or you have an oil pressure problem
kabusheke2004 Thanks this. -
If the engine brakes work ok when the engine is cold then fade when its up to temp it's likely worn rocker shafts.
Big toy repair, flood and kabusheke2004 Thank this. -
Give more information. People leave out important details. How long have you had truck? Is this something just happened over night? Important to know becuase 06 Cummins doesn’t exactly have best jakes compared to other motors of that year so maybe you are used to something else. Have a buddy that has an 06 Cummins and deleted the emissions egr crap off it and it was a total different animal and even the jakes
AModelCat, Itsbrokeagain and kabusheke2004 Thank this. -
I have had the truck for two months now. 1.2M miles. My previous truck was same 06 volvo with a cummins isx that had a 3 stage engine brake. My previous truck would slow me down on a steep grade fully loaded. So definitely something is not right with my current truck
Ok this helps. But I can’t help but someone else will. Isn’t 3 stage basically the same as what you are calling 6 stage? 3 stage brake ####### all 6 cylinders
Ps , the word r.e.t.a.r.d gets censored?????
I thinks time for a new trucker forum. What a sensitive liberal website.Itsbrokeagain, flood, wtxiceman and 2 others Thank this. -
I mean 3 level setting e.g low middle high. My current truck has 1 as the low. Increases to 6 as the high.JMon and Cam Roberts Thank this.
Wire probably came loose on one of the solenoids. I had same issue with my newest truck with cat. Pulled valve covers and tested the jakes with valve covers off and saw wire was loose. Also fixed a buddies trick with same issue. This wires sometimes need to be pulled off and crimped with a pair of needle nose. I wound up just replacing the harness anyhow but just recrimp and retest with valve covers off
Dave_in_AZ and kabusheke2004 Thank this. -
Will do so. Thanks
If this engine was deleted and they changed turbo you lose the high jake setting on many deletes...
