Weak Engine Brake on Cummins ISX
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by kabusheke2004, Nov 28, 2018.
  1. kabusheke2004
    kabusheke2004 Light Load Member
    99
    36
    Jul 20, 2014
    Virginia
    Its been deleted by the previous owner. Maybe it lost some engine braking power when they programmed the ecm. You know how it can be fixed? Maybe have it tuned again?
  3. RoadRanger^^
    RoadRanger^^ Medium Load Member
    317
    118
    Apr 17, 2018
    Columbus, OH
    I have Volvo 2011 670 with cummins isx 500. I delete the egr and dpf crap from my truck and since then i can tell that my engine brake is weaker since that day and when i activate my engine brake is kinda late 1sec it’s not braking right away, but i don’t think it’s that big of the deal(I think this delete makes the engine brake weak.)
  4. 379pete36507
    379pete36507 Bobtail Member
    Can someone help me out I have a Cummins 500 red top the Jake will work only on the brake peddle when sitting still you can rev it up and hit the brake peddle really hard sitting still and it works but will not work when you use the brakes while riding.
  5. Hshappy2
    Hshappy2 Bobtail Member
    6
    May 13, 2017
    Bud did u fix the problem ?
    I have issues jake is weak
  6. Heritage661
    Heritage661 Bobtail Member
    27
    5
    Apr 4, 2016
    What a headache..
  7. Heritage661
    27
    5
    Apr 4, 2016
  8. Kammv
    Kammv Bobtail Member
    Care t
    o explain a bit more please? I’m having an issue with my Jake as well I already changed the turbo 3 times 2 different Vogt valves and the Jake only works at times when it works is fine like any other truck I’ve driven but when it doesn’t is just like I’m using it on low setting no hold at all
