Merry Christmas to all
Have been using my Webasto heater for some 6 years without problems.
Just started giving out some trouble codes, I Idecided it is time for long overdue service/repair
Replaced filter, glow plug, burner, gaskets, clamps, connectors as per recommendations.
Now I get a F01(one blink code). The weird part is that when I start it the first time(and every time after) it works flawlessly. Only after it reaches the desired temperature and shuts down until ready to restart by itself, it trys 2 times and then gives up with F01. At that point if I manually shut it down and then turn it on It fires up immediately as if nothing happened. Until next restart
Anyone experienced this and how to fix it
Thanks
Webasto 2000st problem F01(one blink code)
Discussion in 'Volvo Forum' started by dorlia2, Dec 27, 2018.
I had one do that, turned out to be poor electrical connection to batteries.
dorlia2 Thanks this. -
Either bat connections or the other thing check all clamps for fuel lines I think the system is loosing prime I’ve had a few of them do this over a loose clamps.
Just put a new one. Same thing
Hmmmm maybe getting an air bubble inside the fuel line at a joiner or sag in the line
You would not believe but I put new lines connectors and clamps also
