Webasto bunk
Discussion in 'Ask An Owner Operator' started by Cristian198, Aug 16, 2022.
  1. Cristian198
    Cristian198 Bobtail Member
    I'm trying to troubleshoot my Webasto bunk heater on my 2016 Volvo VNL 780, But I cannot figure out where the bloody fuse is for it. I'm not getting a ticking from the pump nor is the fan kicking on, so I want to check that fuse, but it isn't listed on either internal fuse panel. Anyone know where they stashed it? Thanks!
  3. Dave_in_AZ
    426,343
    Could be it is not getting the go signal just cause something is sensing it's so hot out?
    Mine's a 2014, works like a champ, but you know how eggheads like to improve on things that don't need improvement.
  4. 77fib77
    77fib77 Road Train Member
    11,693
    77,232
    Jul 7, 2010
    St Louis
    Is it doing the light flashing thing?
  5. 86scotty
    86scotty Road Train Member
    4,718
    12,962
    Aug 27, 2017
    Appalachia
    Is it connected to an APU? My Tripac has the bunk heater wiring and fuse at the APU's main board.
    Get a multimeter and check power at the heater.
  6. Mdavid0614
    Mdavid0614 Bobtail Member
    31
    6
    Feb 13, 2019
    Mine wont run on volvo until i pull tractor parking brake. Then its goes.
    Dave1837 Thanks this.
  7. 86scotty
    4,718
    12,962
    Aug 27, 2017
    Appalachia
    Never heard of that set up. Interesting. I guess it's a good idea for safety but mine doesn't have it. I've left mine on a couple of times accidentally
    after I got rolling.
  8. kay_ray
    kay_ray Medium Load Member
    492
    1,236
    Jun 6, 2019
    Fuses are under the bunk . Check the connections to and from the battery first . It might just be loose or corroded harness. The harness do go bad sometimes so volt test it on the webasto end and make sure you are getting enough juice.
