Webasto
Discussion in 'Ask An Owner Operator' started by pavrom, Oct 29, 2018.
  1. pavrom
    pavrom Road Train Member
    3,217
    7,422
    Apr 29, 2012
    NE illinois
    Just asking to share some feedback , advices , experience with product
    I'm looking for webasto unit that will preheat coolant and heat the bunk during night ...don't wanna idle because it's not healthy for the engine , would like preheat coolant for easy and harmless winter starts .
    I see the unit on eBay selling for around 2300$ ...how hard is install if anyone did it by themselves , I can probably do it with good instructions .
    Anyway pls share
    SimpleTrucker and Oxbow Thank this.
  3. I glide 47
    I glide 47 Road Train Member
    1,426
    1,523
    Jun 3, 2017
    Great units love mine, I didn't install just operate. Check out u tube for install videos. Anyway good luck with it.
    pavrom Thanks this.
  4. skellr
    skellr Road Train Member
    8,735
    12,187
    Jul 17, 2011
    The Village, Portmeirion
    One problem comes from the fuel filter. It really does need to be mounted horizontally level. Air bubbles can accumulate and hinder fuel flow if it isn't. Strange problem.
    Oxbow and pavrom Thank this.
  5. Gumper
    Gumper Road Train Member
    1,579
    3,847
    Jan 7, 2018
    Butte, MT
    I just installed an Espar in my truck. I chose them because I’ve heard from several people that Webasto has had some issues, and their customer service isn’t great. I will tell you that having the little diesel heater put in is one of the best things I’ve ever done.
    86scotty, 20 Mule Team, Oxbow and 2 others Thank this.
  6. laaylor
    laaylor Road Train Member
    1,615
    2,451
    Oct 16, 2007
    Creston, Wa
    I have an espar: many years with it: as long as you keep up on the maintenance: they are awesome!!!
    Oxbow and ramblingman Thank this.
  7. sbaumann14
    sbaumann14 Road Train Member
    1,240
    1,441
    Sep 1, 2010
    Rhinelander, WI
    You can get by with an Espar for around $900. Will require cutting hole in floor of sleeper about 5" around, and drilling a 1/2" hole in fuel tank. Very simple to do. Idles all night on a QUART of fuel. A quart. In 10 hours, you just saved 9 1\2 gallons at $3.25 per....do the math.
    One thing i do every year, is at the end eo the season (around April as i live in WI) is disconnect the fuel hose from the tank and stick it in a gallon jug of kerosene. Turn the heater on high, and let it run for an hour or two. Keeps it clean.
    Ive had the same espar for over 5 years now, havent done anything to it as far as maintance.
    Think about it....5 years x 150 days per year x 10 gallons per night....yep, about $25k give or take
  8. adayrider
    adayrider Road Train Member
    1,289
    1,732
    May 7, 2018
    Does the Espar heat the block also or is Wabasto thing only?
  9. skellr
    8,735
    12,187
    Jul 17, 2011
    Different devices. They make both block/coolant heaters and bunk/sleeper heaters but not one that does both.
  10. Mosinee dave
    Mosinee dave Bobtail Member
    40
    61
    Feb 1, 2018
    Putting one on thinging of having a separate tank and run kerosine. Last one seems would not get through the season without a cleaning.
  11. 77fib77
    77fib77 Road Train Member
    11,695
    77,263
    Jul 7, 2010
    St Louis
    If you have a block heater, electrical plug in, get a generator and heat the block with it. Then a stand up portable AC unit for summer, pull the passenger seat. Webesto is smaller and uses diesel, but is more spendy.
