Webasto
Discussion in 'Ask An Owner Operator' started by pavrom, Oct 29, 2018.
  1. pavrom
    pavrom Road Train Member
    3,217
    7,421
    Apr 29, 2012
    NE illinois
    I was looking at this unit or maybe espar because of good feedback
    Webasto: DBW 2010/2016
    Not sure what's best to have ? Separate units or one unit for both functions
  3. bonder45
    bonder45 Road Train Member
    1,803
    5,452
    Oct 2, 2011
    Williston, ND
    Has anyone looked at Proheat? Options for those?
  4. beastr123
    beastr123 Road Train Member
    2,952
    24,213
    Jan 2, 2014
    Moose Jaw SK CAN
    the 2010 and 2016 are both 45,000 btu units min and will only stay running for about 7 hours at 0 degrees because you use the trucks fans to move the air. The airtop 2000st (7000btu)and thermo top c (17000btu) combination is a much better choice in the Webasto line because it has its own low draw/ thermostatically controlled air fan and a timer to set for 2 hours to warm the engine for starting. the block heater will only bring the engine to 120 degrees internal from -20 in 2 hours but the engine will start. I have used both and found the two part system to be far superior. You only need to start and recharge every 30 hours or so. With the 2010 you have to start after 7.
  5. beastr123
    2,952
    24,213
    Jan 2, 2014
    Moose Jaw SK CAN
    the Proheat is similar to the Webasto 2010 and has the same disadvantages.
  6. beastr123
    2,952
    24,213
    Jan 2, 2014
    Moose Jaw SK CAN
    the Espar system and the Webasto two part system are basically the same and have the same advantages.
  7. pavrom
    3,217
    7,421
    Apr 29, 2012
    NE illinois
    I finally ordered webasto bunk heater for now .
    Wajid8705 Thanks this.
  8. pavrom
    3,217
    7,421
    Apr 29, 2012
    NE illinois
    ....gonna order coolant heater later ...what are the advantages vs disadvantages on using block heater vs coolant heater ? ...not sure if I have block heater ( saw it for sale at 80$ )..I don't have generator , my friend suggested to plug it in inverter ( guessing if the truck will start after draining batteries )
  9. I glide 47
    I glide 47 Road Train Member
    1,426
    1,523
    Jun 3, 2017
    Plug in a battery charger to the inverter, problems solved
    tommymonza Thanks this.
  10. sbaumann14
    sbaumann14 Road Train Member
    1,240
    1,441
    Sep 1, 2010
    Rhinelander, WI
    I have my Espar set up on a separate battery that has a solenoid that charges the truck as I go down the road, and shuts off when I shut the truck off. It has run 2 days while at home off this one battery. You could set up 2 batteries and hook up some solar panels to keep them charged up to run the block heated while at home...just an idea. do you have the truck near your house? if so, you could hook up the battery and swing by there a few hours before youre ready to go and turn on the block heater.
  11. pavrom
    3,217
    7,421
    Apr 29, 2012
    NE illinois
    My parking probably 6 miles away ...no problem getting generator there , but in case I need to start the truck on the road after night ( I usually don't shut up truck for more than 7-8 hours during my 4-5 days I'm on the road ) , just installed new engine 30k miles ago and want to take proper care of it ( no idling , easy winter starts etc ) ...not sure if idling at 1000rpm harming the engine , usually raise rpm if truck idles for 30-60min ...
