Webasto
Discussion in 'Ask An Owner Operator' started by pavrom, Oct 29, 2018.
  1. 77fib77
    77fib77 Road Train Member
    12,297
    82,724
    Jul 7, 2010
    St Louis
    A small generator on the cat walk would work for the block.heater? Idk the watts needed for the block heater.
  3. I glide 47
    I glide 47 Road Train Member
    1,426
    1,524
    Jun 3, 2017
    Block heater needs about 1500 watts
  4. Wajid8705
    Wajid8705 Light Load Member
    66
    40
    Jun 9, 2018
    North Carolina
    Which one you ordered and from where?
    I see there are like 50 different bunk heaters on Amazon. Can you share link to the one you ordered.
    Thanks
  5. pavrom
    pavrom Road Train Member
    3,265
    7,607
    Apr 29, 2012
    NE illinois
    Original WEBASTO brand , works great , purchased on ebay , had it shipped from Europe . ...i think paid around $600
    Ps : my buddy purchased chinese one for $150 , works same good
    Wajid8705 Thanks this.
  6. Wajid8705
    66
    40
    Jun 9, 2018
    North Carolina
    I saw this on Ebay it says its genuine made in Germany. Is that something similar you ordered?
    Webasto Air Top 2000 STC Diesel 12V air heater FULL set | eBay
  7. pavrom
    3,265
    7,607
    Apr 29, 2012
    NE illinois
    Thats exactly what i have ... Probably same seller , pls make sure its got all the ducting for air ... Mine didn't have it even though it came sealed, had to figure out . Also check what thermostat its got , i would pay maybe $50 more to have digital one with led display
  8. Wajid8705
    66
    40
    Jun 9, 2018
    North Carolina
    That's the thermostat with this one.
    2nd image of all the things come in the box.
    I seen led display ones I think with Chinese brand.
    Yours came with temperature sensor? Some reviews on Amazon says unit stay on the whole time, you need temperature sensor so it will cut off once reached desirable temperature .
    I didn't see temperature sensor in list of things that come with this unit.
  9. Ezrider_48501
    3,844
    5,135
    Apr 2, 2011
    bismarck, nd
    i can only hope this is meant as a joke. both the inverter and charger both are less than 100% efficient at converting power. so all this would do is further drain the batteries.
    Big_D409 Thanks this.
  10. uncleal13
    uncleal13 Road Train Member
    3,797
    6,300
    Apr 9, 2009
    Humboldt, Sk
    The factory temperature sensor is located in the cab air intake of the heater. It monitors the sleeper air temperature as it gets sucked into the heat exchanger. The controller you have pictured does not have an internal sensor of its own, it just works in conjunction with the one built in the heater.
    The problem with this design. If your heater is mounted under the bed, on a really cold night, it will be extra cold under there. So even if the air temperature in the sleeper is comfortable, the temperature sensor will be detecting the colder under bed air. So it will crank out the heat.
    I’ve had it so bad, that I was sweating inside the truck, turned the controller all the way to minimum. But it still pumps out maximum heat.
    Two solutions. Get the digital controller, it has its own temperature sensor. Or you can buy a remote temperature sensor kit, which I use.
  11. DUNE-T
    DUNE-T Road Train Member
    7,104
    17,337
    May 10, 2015
    Detroit, MI
    You need to get a kit with this
    Webasto unit has a temp sensor inside the intake, so you need to put a duct on it and get it inside the cab also. So it's basically will suck the cabin air thru one pipe and put the hot air back into the cabin through another pipe. Then when the unit senses the air is already warmed up, it will shut itself down
    Find a truck with a Webasto already installed and you will see what I mean. Pretty much all the newer Volvos have them factory installed
