weight distribution
Discussion in 'Questions From New Drivers' started by tbh1957, Jun 6, 2013.
  1. tbh1957
    tbh1957 Bobtail Member
    5
    McCleary, WA
    will sliding the 5th wheel forward take any weight off of the trailer? got 110 lbs to much on tandems, and their all the way back.
  3. okiedokie
    okiedokie Road Train Member
    14,000
    111,255
    Jun 13, 2011
    PNWET
    Yes. 1 hole should do it. Watch your drivers and steer for over weight.
  4. airforcetoo
    airforcetoo Heavy Load Member
    892
    216
    Oct 4, 2011
    Up in the air
    All the way to the back? As in the tires touching the DOT bumper? That's like illegal in a lot of states
  5. airforcetoo
    892
    216
    Oct 4, 2011
    Up in the air
    At least for a 53fter ... Where are u hauling thru?
  6. Balakov100
    Balakov100 Road Train Member
    3,938
    2,641
    May 10, 2012
    Temple, TX
    Seriously...it might shift a little, but not really.
    Moving 5th Wheel FW will move weight from Drives to Steers.
  7. fuzzeymateo
    fuzzeymateo Heavy Load Member
    771
    783
    May 20, 2013
    AZ
    I used to figure 250 pounds per pin on the fifth wheel and 400 per pin on the trailer.
  8. Balakov100
    3,938
    2,641
    May 10, 2012
    Temple, TX
    Guess it depends on your setup, I usully figure the Opposite.
  9. tbh1957
    5
    McCleary, WA
    Swift. Heavy haul. Its a tri axle refer. This is a backhaul. Tractor has a tag and 7200lb steers. Got 42660 on tri's allowed 42500. I 90 scale at cle elem, wa is ALWAYS open. No other way around it. No problem with more weight on tractor.
  10. airforcetoo
    892
    216
    Oct 4, 2011
    Up in the air
    Sorry don't know anything about tri axles ... Don't even know what the heck those are ...
  11. Balakov100
    3,938
    2,641
    May 10, 2012
    Temple, TX
    That changes some things...but Basic Rules should still Apply.
    Anyway, dug this pic up, it's not a Reefer but...yeah you get the idea.
