Weight Distribution
Discussion in 'Experienced Truckers' Advice' started by deafaviator, Dec 16, 2017.
  1. deafaviator
    deafaviator Light Load Member
    81
    113
    Sep 25, 2017
    How should I position 5th wheel to be legal? This is on a tanker (so no sliding tandem) and 5th wheel is currently slightly forward of center location.
    The 40lb gross will get burned off in fuel. I’m only concerned about making the drives legal. All the way back and I’m concerned that would put the trailer overweight.
  3. tinytim
    tinytim Road Train Member
    5,145
    19,395
    Oct 29, 2007
    Northern Ontario
    Sliding the 5th wheel forward will move some weight from the drives to the steer axle but probably not enough. It won't affect the trailer.
  4. pmdriver
    pmdriver Road Train Member
    2,338
    3,503
    Nov 14, 2017
    check to see if you front tires are rated to 13000 and if they are move that up by sliding that 5th forward, then carefull on hard corners because it will be a little front heavy.
  5. TripleSix
    133,828
    Have the significant other get out of the sleeper into the shotgun seat.
    Oxbow, InTooDeep, Coover and 1 other person Thank this.
  6. Hammer166
    7,617
    27,873
    Aug 18, 2007
    ~8600+' and loving it!
    With the amount of weight involved, you would hope that should be "significant others"!:biggrin_2559:
    2 holes forward on the 5th wheel if you have the flat locks, 4 notches on the Holland wedges. That will move close to 1000lbs, exactly how much depends on your wheelbase.
  7. deafaviator
    81
    113
    Sep 25, 2017
    My dispatcher wouldn’t appreciate you calling him fat like that. He doesn’t ride with me anyway.
  8. deafaviator
    81
    113
    Sep 25, 2017
    Thanks friends! We’re golden and ready to roll!
    Steel Dragon Thanks this.
  9. Coover
    Coover Road Train Member
    1,573
    3,593
    Dec 9, 2016
    How& Where did you dump 240lbs.... Let me guess said go on in sweetie I'll meet you at the buffet ;-) lol
  10. deafaviator
    81
    113
    Sep 25, 2017
    Lol you mean 240? Fuel burn off.
    The two scales were about an hour apart.
    Also, looking back, the tank hadn’t fully settled when I did the scale. The second time it was settled. So that’s easily a good chunk of the difference as well.
    Hammer166 Thanks this.
  11. Coover
    1,573
    3,593
    Dec 9, 2016
    Just a little trucker humor! Glad it worked out for you
