Weight problems of dry van load
Discussion in 'Experienced Truckers' Advice' started by Demonrogue, Aug 2, 2016.
  1. Dave_in_AZ
    432,534
    There's been no reply, so he got all the way on the scale, adjusted , and got down the road lol.
    KillingTime and x1Heavy Thank this.
  3. Demonrogue
    Demonrogue Light Load Member
    250
    78
    Sep 21, 2013
    Carson California
    Yeah I got it straighten out sorry for the late reply
  4. Moosetek13
    Moosetek13 Road Train Member
    15,028
    19,104
    Nov 1, 2010
    Burnsville, MN
    No.
    When you weigh you don't want ANY brake set.
    You pull on the scale and set it in second gear, then shut off the engine with it still in gear.
    Then let the clutch out.
    That is the only way to make sure there is no weight transfer between axles.
    Dave_in_AZ, Diggler and albert l Thank this.
  5. Moosetek13
    15,028
    19,104
    Nov 1, 2010
    Burnsville, MN
    I have set my 5th so that the steers are at around 12,300 with a full tank.
    Never a problem at the scale house, and it gives me a bit of wiggle room with the drives and trailer.
    And it does not cause undue wear on the steers.
    If they are wearing funny it is an alignment problem.
    Diggler and KillingTime Thank this.
  6. albert l
    albert l Road Train Member
    1,040
    1,505
    Feb 10, 2013
    On the Road
    Exactly, if I set my tractor brakes when loaded my Right Weigh Gauge in my dash will show my tractor weight get heavier up to 2000 pounds depending on how my trailer is loaded
    Those who set brakes at the Cat scale are not getting a true weigh
    Ever see the signs at a scalehouse not to set your brakes
  7. Wooly Rhino
    Wooly Rhino Road Train Member
    3,367
    5,648
    Jul 6, 2008
    Liberty, Missouri
    Just get a welder and make sure the pins are set once and for all for life. Then you never have to scale it again.
    John Dewart Thanks this.
  8. Diggler
    Diggler Light Load Member
    203
    177
    Dec 15, 2015
    Jax
    I noticed my steers were wearing rippled, look at the tires and both were put on backwards on rotation. They still lasted 150k though. Sometimes I'm glad I drive a plastic FL, I've never broke 11500 on my steers. I'm sure I could if I moved the fifth wheel but never had to do that either. One time was a close call, so I ran down to quarter tank and passed the last scale house before my drop and fueled. That's a budweiser load for ya.
    John Dewart and Moosetek13 Thank this.
  9. windsmith
    windsmith Road Train Member
    7,296
    6,032
    Sep 2, 2011
    NEPA
    That does EXACTLY the same thing as setting the tractor brakes only.
    Like I said, set the tractor brakes or the trailer brakes. Never both.
  10. ChaoSS
    ChaoSS Road Train Member
    3,338
    6,758
    Sep 20, 2014
    You have to wonder what makes people think that locking the wheels with the transmission is any different than with using a single set of brakes.
    windsmith Thanks this.
  11. snowwy
    snowwy Road Train Member
    20,618
    13,340
    Jul 6, 2009
    I believe the signs at the scales say DON'T use brakes.
