Weight scale ticket
Discussion in 'Experienced Truckers' Advice' started by CREnglheimen, Nov 3, 2020.
  1. CREnglheimen
    CREnglheimen Bobtail Member
    14
    17
    Apr 29, 2020
    i had a load that was 35000 pounds. I didn’t scale the load because I knew it wasn’t overweight. I could tell by the pressure gauge that it wasn’t a heavy load. It was a little heavy on front airbags when I picked it up but was easily able to slide tandems towards front. When I left the psi was just under 58. So I went through a few scales with no problem. But when I went through a scale in Arizona the weight shifted to the rear and made my tandems heavy. I know it shifted because the psi went down a lot on front and I went through a few scales before with no problem. I went up some hills think that made it happen.I got a ticket for 1500$. Even thought I was able to readjust to correct weight by sliding tandems back to rear. What do I do about this
  3. CREnglheimen
    14
    17
    Apr 29, 2020
    Also it was a pre loaded trailer so I couldn’t see if they secured it with locks
    Socal Xpress Thanks this.
  4. kylefitzy
    kylefitzy Road Train Member
    4,752
    19,798
    Aug 12, 2007
    Kansas city,Mo
    Plan A: Stop and fix the problem before you get a $1500 ticket?
    Plan B: Build a time machine, then do plan A!
    beastr123, Roberts450, drh72 and 5 others Thank this.
  5. I glide 47
    I glide 47 Road Train Member
    1,426
    1,523
    Jun 3, 2017
    Always weight every load, when you noticed the psi going down you should have reweighed the load, you're the captain of the ship, you'll have 1500 reminders! Cat scales
    drh72 Thanks this.
  6. CREnglheimen
    14
    17
    Apr 29, 2020
    I didnt notice until I was on the scale and the lunch lady on the computer had that no lunch for you look
  7. Dockbumper
    Dockbumper Road Train Member
    3,778
    9,863
    Apr 29, 2020
    I always scale ANY LOAD over 30k. A Cat Scale ticket could prove that the "load shifted", if indeed it did. Then you would have a leg to stand on in court. Good luck
  8. goforce
    goforce Light Load Member
    168
    76
    Apr 12, 2007
    South, Ga
    And if the load shifted then they would write you up for unsecured load.
    RockinChair, drh72, AModelCat and 3 others Thank this.
  9. Final Drive
    Final Drive Road Train Member
    1,573
    2,505
    Jan 21, 2015
    Houston, we have a problem..
    I glide 47 and cjb logistics Thank this.
  10. Dockbumper
    3,778
    9,863
    Apr 29, 2020
    OP stated he picked up a pre loaded sealed trailer.
  11. ZVar
    ZVar Road Train Member
    10,911
    23,833
    Sep 10, 2010
    Flint, MI
    So? It's still his responsibility.
    Yes I know it sucks, but it is what it is.
