Weight
Discussion in 'Questions From New Drivers' started by Coffey, Oct 12, 2019.
  1. PowerBstrd
    PowerBstrd Light Load Member
    84
    79
    Sep 1, 2015
    Scale your truck with a full load, then do it empty. Note the suspension gauge each time.
    For example, all our Macks generally read 65PSI @ 79.500, and 13PSI@ 27.500
    MACK E-6 and Coffey Thank this.
  3. Long FLD
    Long FLD Road Train Member
    12,960
    54,395
    Mar 4, 2015
    If that were my truck you’d be way heavy on the drives. But like others have said, all trucks are different. Scale it now and see where you’re at for the pressure it’s at, that will give you an idea.
    The fuel filter can either read as restriction (goes up as the filter plugs) or as flow (goes down as pressure drops). The last KW I drove (2017 model) was flow. If it was cold out and the needle started dropping you were fixing to have some problems.
    TripleSix and Coffey Thank this.
  4. Coffey
    Coffey Heavy Load Member
    715
    1,746
    May 14, 2019
    I will scale it Monday when I got pick up a load if I'm passing a scale
  5. TripleSix
    133,658
    That’s correct. Once it starts going red, it will clog in a couple days. Priceless in the winter. It will let you know before the truck starts sputtering if your fuel begins to gel.
    jammer910Z, Coffey and MACK E-6 Thank this.
  6. Espressolane
    18,756
    117,702
    Having air pressure gauges for your suspension are great.
    The thing is, until you get used to what it is telling you, probably a good idea to still scale loads.
    Might take just a few, or ten.
    Every time you scale the truck, write down what your pressure and weight is, then you can use it as a reference guide.
    Last, when in doubt, scale it. Nothing worse than looking at your gauge and the weight citation.
    jammer910Z, Just passing by and Coffey Thank this.
  7. Fold_Moiler
    Fold_Moiler Road Train Member
    1,926
    3,529
    Mar 17, 2017
  8. Coffey
    715
    1,746
    May 14, 2019
    I do it ever Friday or Saturday but it gets dirty fast from gravel road
    Fold_Moiler Thanks this.
  9. Fold_Moiler
    1,926
    3,529
    Mar 17, 2017
    Yeah I’m in and out of quarry’s a lot. I just keep the windows up and ac blasting.
    Coffey Thanks this.
  10. Shawn2130
    Shawn2130 Heavy Load Member
    896
    1,900
    Sep 20, 2015
    Southern Ontario
    My dash is dirty too.
    Truck has no A/C and windows always down.
    Hard to keep clean as I’m in construction sites a lot.
    I’ve installed air gauges to help me see how heavy the load is on the axles.
    The sterling truck I used to drive maxed out at 80 psi for 18,000 kg on the drives
    The freightliner I drove after has the same suspension, but maxed out at 75 psi for 18,000 as well.
    The freightliner has more unsprung weight, heavier 46,000 rears with full lockers and the sterling is only 40,000 rears with only interlock.
    Coffey Thanks this.
