weird front steering tire wear please help #
Discussion in 'Ask An Owner Operator' started by forevertrans, Apr 15, 2017.
  1. LumbraX
    LumbraX Medium Load Member
    394
    443
    Sep 12, 2015
    Orlando, FL
    I'm running Gabriel Gas SLX all the way around. They are somewhere just over a year old so maybe 60,000 miles on them. The steer shocks don't appear to be leaking or not functioning properly. The wheel hubs (king pin is built in on Volvos I believe) were replaced 2 years ago. I'm running the steers at 110 on the mark. Thanks
  3. boneebone
    boneebone Road Train Member
    2,297
    2,373
    Mar 13, 2009
    Check your front Hub Bearings for excessive play and check Drag Link for wear and play.
    LumbraX Thanks this.
  4. LumbraX
    394
    443
    Sep 12, 2015
    Orlando, FL
    Ok will do.
  5. Kitty power
    Kitty power Light Load Member
    64
    23
    Apr 12, 2017
    YOKOHAMA for ever steer only looks like you covered it can't say any more than that Kittypower
  6. Big_D409
    Big_D409 Medium Load Member
    552
    729
    Dec 1, 2012
    Robertsdale, AL 36567
    I use to have this problem and I always thought it was the RY617. Then I switched to Michelin and started getting that wear 50k miles in.
    Found a shop that did just suspension and they point out my issues. Had many recommendations for them, that were all reputable, so I trusted them. Went ahead and had the front springs replaced and the rear spring bushings. Top it off with an excellent alignment and I haven't seen that wear issue since.
    I'd look for a shop that does just suspension/alignment that is reputable and go from there. An alignment can do wonders or point out flaws.
  7. frankqin123
    frankqin123 Bobtail Member
    8
    Yes only driver side outside
  8. frankqin123
    8
    Yea just the driver side outside. Right side is good
