Weird sound in engine every few seconds
Discussion in 'Ask An Owner Operator' started by simongrewal, Aug 18, 2022.
  1. uncleal13
    uncleal13 Road Train Member
    3,797
    6,300
    Apr 9, 2009
    Humboldt, Sk
    Seeing as the oil pressure dropped.
    Has the oil pickup tube seals been replaced?
    That is a common problem with that engine.
    I think also the fuel quantity valve can make that sort of noise. Although the engine tends to surge with that problem.
  3. Dave_in_AZ
    450,756
    I haven't had any experience with that, so I really don't know what to tell you on that one.
    I'm not a big fan of the high mileage truck. Worked for a guy with a fleet of high mileage Cascadias, and they had a lot of issues. Something was always breaking.
  4. simongrewal
    simongrewal Light Load Member
    52
    37
    Sep 17, 2017
    Indianapolis IN
    It is surging too. It started surging like 10-15 days ago. I was about to get fuel quantity valve replaced but before that this sound started. I had suction tube o rings replaced approximately 400,000 miles ago. It surges pretty bad on cold starts and it decreases when engine is fully warmed up.
  5. Heavyd
    Heavyd Road Train Member
    7,842
    6,297
    Feb 4, 2009
    Any rotating or reciprocating part that is damaged will make a constant noise that will change with rpm. This is not constant but cycling. So it may be something like an egr or throttle valve trying to move or air compressor loading/unloading, something along those lines. I do not know DD at all unless we go waaaaaay back to good ol' 60 series days, LOL! Hope it is something easy and low cost to fix.
  6. simongrewal
    52
    37
    Sep 17, 2017
    Indianapolis IN
    Thanks for reply. Yes i heard Detroit 60 were good engines. Never drove that though but heard from so many people. My Mechanic couldn’t find cause of this sound on Friday. He will check again on this Monday. Hope for best.
  7. AModelCat
    166,503
    The only way I'd put a used engine in anything was if I opened it up and went thru it first. Otherwise you're just buying another problem. $15k-$18k is a great start for rebuilding what you already have.
    86scotty, larry2903, Vampire and 2 others Thank this.
  8. simongrewal
    52
    37
    Sep 17, 2017
    Indianapolis IN
    Good suggestion. So better to get rebuild own engine.
    Rideandrepair Thanks this.
  9. D.Tibbitt
    161,193
    Can u get a stethoscope on it and find where the sound is coming from
    simongrewal Thanks this.
  10. simongrewal
    52
    37
    Sep 17, 2017
    Indianapolis IN
    Truck is at mechanic now. Its like 45 mins drive. He is a good mechanic and have good experience with freightliners. He will check if tomorrow on Monday.
    Rideandrepair, Heavyd and D.Tibbitt Thank this.
  11. simongrewal
    52
    37
    Sep 17, 2017
    Indianapolis IN
    Engine died with continuous grinding sound for 1 minute. Before that it gave CEL with code SPN723 Fail 11.
    Mechanic couldn’t find that weird sound issue and asked me to drive unless it gives code. I was trying to take it to other mechanic but i could only drive it for 65 miles i think. Need to get it towed now
    77fib77 Thanks this.
