Weird tire wear, thoughts?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by irishluck09, Nov 16, 2024.
  1. irishluck09
    irishluck09 Light Load Member
    296
    183
    Nov 24, 2019
    This is on my step deck. I'm going through this tire once a month, brand new tires. Can not figure out why this wear pattern is occurring? The inside of it is showing cord. Has proper air. Never hauls more than 45,000lbs. Never over axles weights.
    Can not figure out what's going on. I'd have said an axle alignment maybe except the inside tire looks just fine. Only the outer tire.
    Thoughts?
  3. Lazer
    Lazer Road Train Member
    1,850
    2,983
    Jan 22, 2017
    Have tried swapping tire and rim positions?
  4. Arctic_fox
    4,554
    25,878
    Sep 16, 2016
    If its just the one tire it COULD be a very slightly bent rim. I have run into that before. Easy way to rule it out is to move the rim, if a tire wears funny in the new position trash the rim and get a new one.
    Otherwise id still start with an alignment after moving the rim. It rules out like 95% of common issues. For example if you curbchecked that wheel it may have slightly knocked it out of alignment or something. Its a cheapish way to rule out most issues. If it goes away great problem solved. If not then we start getting to expensive ####.
    For example that pattern looks like when i had a shot wheel bearing, easy way to check is spin it while its jacked up for an alignment and moving that rim and see if it makes noises. Wont always make noise if its shot, but if it does there is likely a good chance it IS a bearing issue. That said though it could also be a slightly bent spindle if you whacked something just so.
  5. irishluck09
    296
    183
    Nov 24, 2019
    But if if it was an alignment issue or bearing, wouldn't it affect both tires? It's only affecting 1.
    Rideandrepair, MACK E-6 and 201 Thank this.
  6. AModelCat
    165,108
    That suspension hanger looks like its rotted out pretty good.
    Rideandrepair Thanks this.
  7. 201
    201 Road Train Member
    12,826
    26,411
    Apr 16, 2014
    high plains colorado
    I believe that's from mismatched tires. They have a different tread pattern. The inside might be a tad shorter.:dontknow:
    Heavyd, Concorde, Oxbow and 2 others Thank this.
  8. Arctic_fox
    4,554
    25,878
    Sep 16, 2016
    You would be suprised. My pete was slightly out of alignment and would only ever chew up the one tire because it was only off a bit. Didnt matter if i put 2 new ones on, moved rims ect. Kept cheewing up my inner tire. Then i got it aligned and the problem went away.
    Same with a bearing. Had one on my drop axle going and it kept eating my outside tire. Replaced the bearing and it fixed the issue.
    There is a reason an alignment is the first recomended step by many though. You would be AMAZED how often that fixes all kinds of weird issues. And even if not. An alignment never hurts anything and rules out most common and a lot of uncommon amd rare tire wear issues.
    Good catch, i missed that entirely.
    201 and Concorde Thank this.
  9. Rideandrepair
    17,576
    56,941
    Aug 8, 2015
    All of the above. Definitely check wheel end play. May just need to tighten up bearings. Usually the inside tire will wear more in the same way. Being mismatched, ???? Easiest things to check, along with a bent wheel. Jack up, try to move it back and forth, see if it’s loose. Then spin wheel, with a big socket or anything up against the wheel. Bushings? Might notice it dog tracking a lot. Often intermittently, depending on where the arm is at while it’s moving around. Alignment? All three?
    D.Tibbitt and Concorde Thank this.
  10. Concorde
    Concorde Road Train Member
    5,506
    19,606
    Jun 29, 2016
    West Melbourne Florida
    That’s what I was thinking. Mismatched tires and likely the inside tire is taller. TA put a 11R next to one of my 295 75 lo pro and the 295 was completely bald after one day running 75mph.
    201 and Rideandrepair Thank this.
  11. Rideandrepair
    17,576
    56,941
    Aug 8, 2015
    Y
    Yep, shorter tire takes a beating. On mine it’s always flat spots. Maybe from bad shocks? Also any time I put a used steer with inside wear, wouldn’t last long. Once the pattern’s established, that’s it. A tires only as good as it’s low spots. The exception is drives. For some reason, a used steer with established inside wear on my drives will run a long time without getting worse. Something to do with torque pressure vs. free rolling trailer or steers, is my guess.
    Concorde Thanks this.
