Weld or change? Broken bell housing
Discussion in 'Experienced Truckers' Advice' started by Gurjap, May 31, 2024.
  1. Gurjap
    Gurjap Light Load Member
    57
    11
    Mar 18, 2020
    Hello I have a Mack tractor truck and come to find out the bell housing is cracked. Is it okay to get it welded or do I need to change the entire thing?
  3. Diesel Dave
    9,681
    32,884
    Jan 20, 2010
    Hesperia, Ca.
    Change, replace. I believe most of them are cast aluminum.
    Gurjap, TX2Day, Deere hunter and 3 others Thank this.
  4. Ridgeline
    22,725
    123,411
    replace
    why did it break?
    Gurjap, tscottme, TX2Day and 2 others Thank this.
  5. 2Tap
    2Tap Medium Load Member
    458
    931
    Jul 19, 2022
    Southern Wisconsin
    A 'lil JBWeld and you'll be good another 200 miles.
  6. W923
    W923 Road Train Member
    1,419
    4,389
    Feb 28, 2022
    I would replace unless that’s not an option
    Maybe depending on exactly how and where it’s broken I might consider welding…which is entirely possible just might cause to much distortion and therefore affect alignment of the input shaft/clutch/flywheel
    Gurjap, 2Tap and Diesel Dave Thank this.
  7. Gurjap
    57
    11
    Mar 18, 2020
    The bolts on the top opened and there was a lot of vibration. We believe they opened because we got the clutch adjusted. Ended up being adjusted wrong and it became stuck. Followed by a lot of vibration. Vibration cause the bolts to break. And then the entire thing cracked
  8. Ridgeline
    22,725
    123,411
    So essentially the bolts were not tighten down to the proper torque, worked their way loose and caused the crack - IS this right?
    I don't understand how the bolts at the top would be affected by a clutch adjustment.
    Replace.
    AModelCat and Big Road Skateboard Thank this.
  9. Big Road Skateboard
    7,101
    40,321
    May 2, 2021
    What I saw a lot of. Trans or clutch worked on. Bell housing bolts not torqued, often overtightened, or just stripped the holes in the flywheel housing.
    Driver thinks clutch is acting funny, needs a clutch adjustment.
    Tech usually doesn't see the 1" gap at the top of the bell housing and just adjusts the clutch.
    Bell housing is already screwed by that time.
    And the shop that did the work originally makes ridiculous excuses, like a "stuck clutch" caused the whole situation
    AModelCat and W923 Thank this.
  10. AModelCat
    164,754
    Change the housing. Cost to weld/repair properly, if even possible, will probably be on par with replacement.
