well guys i need help again sorry
Discussion in 'Trucks [ Eighteen Wheelers ]' started by earthmover, Jun 30, 2010.
  1. earthmover
    earthmover Medium Load Member
    563
    20
    Jan 27, 2009
    castalia , north carolina
    well i drive my dump at night and have a driver that drives doing the day and he told me a while back that the truck would kinda slip out of 1st gear some times not all the time..well today he calls at about 12 and said its slipping out more often in 1 and 5 same place and sure enough i drove it when he came in an it just dont want to stay in gear ...im hopeing i dont have to get someone to go into the trans but i feel that thats where the problem is inside but thought i would ask i went under to check the fluid and it was a little low theres a leak some where thats not been there so i add fluid but didnt drive it again cause it did the same thing in the yard in 1st... could someone give me some ideas of what to do please...thanks mike..sorry guys i forgot its a eaton fuller 9 speed low and low low thanks
    kickin chicken Thanks this.
  3. xTHANATOPSISx
    xTHANATOPSISx Light Load Member
    77
    32
    Feb 12, 2010
    Hutchinson, KS
    I've never seen on that was spitting the shifter out that didn't end up getting rebuilt, but it could be simpler. Either way, it's likely internal. Just in case, does anything happen at the same time? If you have a shift tower or linkage problem, a twist in the cab suspension or frame could pull it out of gear.
    If it just pukes it out of gear when you load the driveline, I'd expect it's terminal and bearing related, but it could be a problem with a bent shift fork or similar situation. Either way, I'd be afraid it's going to let you down sooner, rather than later.
  4. FYDA FREIGHTLINER CINCY
    FYDA FREIGHTLINER CINCY Light Load Member
    270
    131
    Apr 28, 2009
    Cincinnati, ohio
    sounds like u have a sliding clutch wore out.
  5. Heavyd
    Heavyd Road Train Member
    7,826
    6,276
    Feb 4, 2009
    Yep, sliding clutch is not fully engaging between the gear and main shaft. Could be worn shift tower, worn fork, worn sliding rail, broken detent spring. Tower and top cover are replaceable without overhauling or replacing the trans. It depends on how undriveable it is right now and how hard it would be get access to top of trans to say whether or not it would be worth replacing just the top or going for a whole rebuilt trans. If you can live with it, I would say continue to use. If you are due for a clutch soon then do the trans then.
  6. heyns57
    heyns57 Road Train Member
    2,209
    1,011
    Dec 30, 2006
    near Kalamazoo Speedway
    This reminds me of a tractor I drove for Tri-State Motor Transit in the late 1960s. It began to slip out of high gear when power was applied. We rowed it to Joplin.
  7. earthmover
    563
    20
    Jan 27, 2009
    not up to speed on a sliding clutch what is that??? i just replaced the clutch 2 yrs ago. i mean the truck can be drove just best not to use 1/5 and use the rest but what would make it go out like that???i had to replace the front mounts on the motor this yr would that cause something like that??? now the big 1 is it something i could do???? or is it something thats going to cost me out the rear... man you just cant win in this buisness can you...thanks for all your help guys ill take any sugg. that you have to help so please keep them coming mike
  8. Powder Joints
    7,988
    8,406
    Sep 25, 2007
    Rosamond, SoCal
    Attach a bungee cord from the edge of the seat so you can wrap it around the shifter.
    Sometimes you can smack the spinning thingy with a big enough hammer to cause a flat spot so it will wedge itself into place.
    Better yet, while you have it out to hit it with a hammer, give to your mechanic.
  9. earthmover
    563
    20
    Jan 27, 2009
    i hope thats a joke right....
  10. FYDA FREIGHTLINER CINCY
    270
    131
    Apr 28, 2009
    Cincinnati, ohio
    the sliding clutch is what engages the gear. its on the mainshaft and splined to the mainshaft. the outside of the sliding clutch has teeth on it which mate to the inside of your main box gears. the shift fork slides over the sliding clutch, when u move the stick the shift fork moves the sliding clutch inside the gear you selected, which connects that gear to the mainshaft. you have 3 sliding clutches. when the sliding clutches wear the teeth round off to a point instead of the teeth being square. thats why it jumps out of gear. the trans will need to be completly disassembled to replace clutches. the lower counter shaft does not need to be removed
  11. Heavyd
    7,826
    6,276
    Feb 4, 2009
    Just drive it.
